12-21-2007 09:36 AM - edited 03-15-2019 07:55 AM
Is Advanced Enterprise required to configure a 2811 to be a H323 GW?
12-21-2007 10:18 AM
You can configure an h.323 gateway with Advanced IP Services. I am currently running a 2801 with Advanced IP Services an an h.323 gateway.
Hope this helps. If so, please rate the post.
Brandon
12-21-2007 11:21 AM
Thank you for your straight forward answer. May I try another? Is Advanced Enterprise required on a 2851 to configure Gatekeeper. I plan to configure one as primary and one as alternate.
12-21-2007 12:50 PM
Hi, GK in current 12.4 code requires _ivs image, so your choice is restricted to either "ip voice", or "advanced enterprise K9".
