Can I bypass the menu number option in BACD script?
Hi All,
I'm trying to setup the BACD in CME as a backup solution when the connection to main system failed. It seems like the default queue tcl included in the router always give the customer option to push menu number like push 1 to reach .., push 2 to reach... So for us, we only have one hunt group and don't need this menu option. The customer will hear welcome prompt and then will be put into the queue or just go directly to the available agent. Do I have to modify the default TCL script or some commands can do this?
Thanks a lot.
Lou
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
Re: Can I bypass the menu number option in BACD script?
Hi Lou,
I think this config may work for you
Cisco Unified CME B-ACD with Drop-Through Option: Example
The following example sets parameters for an AA service called aa and a call-queue service called callq. The direct-dial number to reach the AA service is 800 555-0100. Callers to this number drop through to the ephone hunt group that has a pilot number of 5071 after hearing the initial prompt from the file en_dt_prompt.au.
dial-peer voice 1000 pots
service aa
port 1/1/0
incoming called-number 8005550100
ephone-hunt 10 sequential
pilot 5071
list 5011, 5012, 5013, 5014, 5015
timeout 10
application
service callq tftp://192.168.254.254/user1/CallQ/B-ACD/app-b-acd.tcl
  param queue-manager-debugs 1
  param aa-hunt1 5071
  param number-of-hunt-grps 1
  param queue-len 10
service aa tftp://192.168.254.254/user1/CallQ/B-ACD/app-b-acd-aa.tcl
  paramspace english location tftp://192.168.254.254/user1/prompts/
  paramspace english index 0
  paramspace english language en
  param aa-pilot 8005550100
  param service-name callq
  param handoff-string aa
  param second-greeting-time 60
  param drop-through-option 1
  param drop-through-prompt _dt_prompt.au
  param call-retry-timer 15
  param max-time-call-retry 700
  param voice-mail 5000
  param max-time-vm-retry 2
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/bacd/configuration/guide/40bacd.html#wp1003141
Cheers!
Rob
Hi there,
Yes, it can be done by utilizing what is called drop through mode.
Please see:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/bacd/configuration/guide/40bacd.html#wp1058600
There is an example further down on this page.
HTH,
DK
Hi Lou,
service aa
port 1/1/0
pilot 5071
timeout 10
application
  param aa-hunt1 5071
  param queue-len 10
Cheers!
Rob
Thanks a lot. Can I have two different queue and two different drop through aa with two different welcome prompt? If I can't modify the prompt name, it seems like I can't have two different welcome prompt.
Lou
Yes, you can have multiple queue with diff. drop through aa.
There shd be an example on the same page I sent earlier.
The welcome prompt name is hardcoded in the script so
you can replace it with your own recording as long as you
do not alter the filename.
HTH.
DK
Thanks DK. So that means the "en_dt_prompt.au" below can't be renamed, right? I know "en_welcome_prompt.au" can't be modified. But I didn't find statement in documentations saying "en_dt_prompt.au" can't be renamed. It seems like en_dt_prompt.au is not default prompt.
40tcl.bookparam drop-through-prompt _dt_prompt.au
Lou
Hi Lou,
I take that back...looking at the doc, it seems the restriction for en_welcome_prompt.au
has been lifted...checkout Table 2
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/bacd/configuration/guide/40bacd.html#wp1012403
en_welcome_prompt.au  Filename can be changed; must match the name specified in the param welcome-prompt command.
It appears that u can also rename bacd_welcome prompt as well as drop through prompt...from the same doc...
The two exceptions to the general filenaming rules are the  welcome-prompt audio file (default is en_bacd_welcome.au) and the  drop-through-option prompt audio file (no default supplied). The  identifying parts of the filenames for these two audio prompts are  specified explicitly during configuration and are completely  user-configurable. These files may use any filenames as long as the  names observe the following conventions:
The prefix part of the filename must be the same as the language code that is specified in the paramspace language command. For example, en.
The identifier part of the filename must start with an underscore. For example, _welcome_to_xyz.au.
So its a matter of pointing your application params to correct filenames on the flash.
DK
Cool!!! Thanks for pointing out! That works.
Hi there,
Please see:
HTH,
DK
449
