hello,
we are forced by changing the time the September 1th to decrcease by 1.Now,Our Timezone is GMT+1, but if i change the timezone to GMT will has the same effect as if i decrease the time by 1.
The following is a check that must be done before installation of CUOM :
Critical: Check the time on the machine. If you change the time after CUOM installation you may need to reinstall the OS to get CUOM to work.
Thanks at advance
