Can I config an H323 GW in a 2811 with Advanced IP Services
GrayH
I currently have 50+ 2811's working as analog E&M gateways. Dial peers are configured in each router. I have 2 2851's at the main site as T1 CAS Gateways. I want to create a Gatekeeper controlled network with 1 or 2 centralized dial peers. I know I need Advanced Enterprise to configure Gatekeeper in the 2851's. Can I reconfigure my 2811's as H323 Gateways with Advanced IP Services
jolo07310
Level 5
Level 5
You are correct.
However, You can use ipvoice_ivs-mz image for Both H323 and Gatekeeper.
You can use Cisco Feature Navigator tools, you might need CCO account. It is very easy to use.
http://www.cisco.com/en/US/support/tsd_most_requested_tools.html
Please rate the post if help.
Ken
