Can I create a login for CM that will restrict access to certain areas?
Specifically, I only want this login to access the User Management menu, so that they can modify the End Users.
Re: Can I create a login for CM that will restrict access to cer
yes and no. Please lookinto the administratin guide. you can create users with different roles. They come with pre build roles just like your pc admin, guest, and super user.
what you're looking for is MLA, you need to add the user to a group and assign roles to the group
think of the roles as the access permissions, you can enable only view access or allow changes
java
if this helps, please rate
www.cisco.com/go/pdi
110
