Can I make a test VOIP call from Router CMD line
I had a problem with my voip config,after some good advice from this forum I have made some change to the config.
are there any commands i can use to make a test voip call between the routers, so i can check if the new config works.
Re: Can I make a test VOIP call from Router CMD line
try
csim start #####
csim start is a legacy command, and I find it only works well for pots test calls. The router doesn't have this capability, but csim start is the only command.
-nick
1075
