11-06-2009 06:17 AM - edited 03-15-2019 08:23 PM
Can I send text message from Cisco IP phone to other phone?
11-06-2009 06:47 AM
No, unless you write an application for that.
11-06-2009 10:33 AM
Does cisco offer some kind of applications? Where I can find them?
11-06-2009 10:36 AM
Cisco does not make this application. I'm not aware of anybody that does.
11-06-2009 11:13 AM
If the "other phone" is a Cisco IP Phone CUPS has IP Phone Messenger (IPPM) feature for this
There's plenty of info on CCO about the feature if you're interested, otherwise as Paolo mentioned it would require a 3rd party depending on who the "other phone" is.
java
if this helps, please rate
