01-07-2008 04:01 PM - edited 03-15-2019 08:05 AM
I want to set my Cisco CME (using version 4.1) to always show the same phone number for caller ID, no matter which actual phone the call is placed from. Is there any way to do that?
I appreciate any help,
01-08-2008 03:21 AM
You can do a lot of stuff with CME and CM, problem is the provider. For example when you have mutiple BRI interfaces, the provider normally sets the caller-ID to the number belonging to the interface, regardless of what you configure.
With E1/T1 you could set all calls to use the main (head) number.
Hope this helps,
Jan
01-08-2008 08:56 AM
That's exactly what I want to do, is there any way that you can explain to me the steps necessary to do that?
01-09-2008 12:06 AM
You have BRI or E1/T1? Because normally each BRI has its own number and you have difficulties setting caller-id
I am not so familiar with CME, but CME uses dialpeers, so you could use the clid command:
Read this and try it,
Bye,
Jan
