Can I terminate a SIP trunk on an existing MGCP gateway?
Hello all,
Running CUCM 7.1.5 and currently have a Cisco 2811 with 3 PRI circuits as a MGCP gateway.  We are bringing in a SIP trunk from our telecom provider for evaluation and I was wondering -- can I use that same router to terminate the SIP trunk handoff from the telco without affecting any of the existing PRI circuits?
As I understand, you don't need a voice gateway for a SIP trunk, correct?  It is simply defined in CUCM.  All I need is a place to terminate the Ethernet handoff the telco is going to give me.  Am I on the right path?
Thanks, I have never done SIP trunking before so this is all new to me.
- Chris
Everyone's tags (3)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Chris,
Yes, you can.
You will require CUBE licenses though, these are not enforced but from licensing perspective you need to order CUBE licenses for each concurrent call.
HTH,
Chris
Chris,
Yes, you can.
HTH,
Chris
Chris,
Thank you.  That is exactly what I needed to know.  I will look into adding the licensing as we have a large Cisco purchase coming up this month anyway (SMARTnet renewal time).
Chris
922
