Community Member
Can I unblock my outgoing calls?
Hey All, I work in sales and prospects are turned off by blocked calls. Wondering if there is a dial sequence when making an outgoing call to unblock it?
1 REPLY
Re: Can I unblock my outgoing calls?
could be, but it has been set by your network administrator so get in touch with him as there is no default code.
other option is he's just blocking the calls and there is no way to make those calls
java
if this helps, please rate
java
www.cisco.com/go/pdi
414
