Can I upgrade a C1861-SRST-F/K9
Can I add a AIM-CUE to a C1861-SRST-F/K9 bundle ... I purchase the wrong bundle and I need VM ... Configurator doesn't allow the upgrade the router and I don't see a licence ... I wanted to know if Cisco supports this upgrade ?
Hall of Fame Super Gold
Re: Can I upgrade a C1861-SRST-F/K9
I think that nothing prevents a regular AIM-CUE to be fit in the router and work with the appropriate SW image.
If you look here: http://www.cisco.com/en/US/prod/collateral/routers/ps5853/ps8321/product_data_sheet0900aecd806c4dce.html
Table 2 lists it as an option, but I don't see a part number.
You are right, but knowing cisco, I think the AIM-CUE that sells as spare, is the very same that goes as optional with the 1861.
No, 1861 have not any AIM
No, 1861 have not any AIM slots inside. CUE processor and DRAM/FLASH slots are included in SRST-F bundel on main PCB. How upgrade it I dont know.
221
