Can I use IP phones if I terminate analogue on a VG224
Hello all
Can I use IP phones once I have terminated analogue lines into a VG224 from my UC500 paltform?
1 ACCEPTED SOLUTION
Re: Can I use IP phones if I terminate analogue on a VG224
The VG224 provides 24 FXS ports which can be used to connect analog phones, fax machines etc. It cannot be used to connect external analogue lines.
You need a device with FXO ports for that purpose. You can fit up to 8 FXO ports into a UC520. If you need more trunks then it makes sense to look at an T1/E1 link or optionally SIP trunking.
Hi James
I know this a bit late but thanks for the response....as you were correct in what you said. I will score this as answered.
175
