07-23-2013 10:40 AM - edited 03-16-2019 06:30 PM
Hello Everyone,
There is a 'local speed-dial' Cisco CME feature which provides a system-wide list of frequently called numbers (up to 32) accessible from the directory button on the phone. ( this is done by creating/uploading speeddial.xml file )
I wanted to know if this feature is availabe on CUCM System version: 7.1.5.33900-10
Please help
Thank you!
Atul
Solved! Go to Solution.
07-23-2013 11:06 AM
No, closest thing you get is to configure translation patterns to do the same.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
07-23-2013 11:06 AM
java
07-24-2013 08:25 AM
Thanks!
