Community Member
Can Meet me conf. beep when participant joins?
On CUCM 7.1.3, I want to have a beep when someone joins.  Otherwise, It would be better to have the participant names announced when joining.  So, my main question is: Can a Meet-me conference be configured to beep when a participant joins?  If not, can I use Unity Connection to collect the name and transfer?  Thanks.
Everyone's tags (4)
Hall of Fame Super Red
Re: Can Meet me conf. beep when participant joins?
Hi Anthony,
I believe this is what you are looking for;
Service Parameters Configuration > Clusterwide Parameters (Feature - General)
Party Entrance Tone - True
Hope this helps!
Rob
CUC can do what you want so both are valid options. Just beep or ask name and announce.
Ask Me If I Want to Take the Call
Check this check box to have Cisco Unity Connection ask users whether  they want to take a call before transferring the call.
This option is unavailable when Release to Switch is selected or when  the Transfer Calls To setting is set to the Greeting option.
Note Transfer options apply only to  indirect calls; they do not apply when an unidentified caller or another  user dials a user extension directly.
Default setting: Check box not checked.
Ask for Caller's Name
Check this check box to have Cisco Unity Connection prompt callers to  say their names. When answering the phone, the user hears "Call from..."  before Connection transfers the call.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Community Member
Thanks Jave,
    That's what I wanted to know.
   Anthony
Community Member
Thanks Rob,
   I checked and this feature is set to true but the customer says that there's no beep when participants join the conference.  Is there another setting, or does something need to be reset?  Or, even a bug maybe?
  Anthony
628
