08-29-2012 06:39 AM - edited 03-16-2019 12:56 PM
Our customer used to have a choice where they could dial outbound via the ISDN 30 (E1) if they dialled the number without pressing a 9 first and if they pressed 9 first the call would go out via the SIP trunk.
For some reason this has stopped working if you press 9 and dial the number the call doesnt seem to go anywhere.
The config is attached and the SIP dial-peer is 1 if anyone can see any issues. that would be much appreciated.
Solved! Go to Solution.
08-29-2012 07:14 AM
Your provider is rejecting your call..Says IP not authorised. You may need to check with them why they are rejecting your call...
Aug 29 14:59:50.593: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 IP not authorised
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
08-29-2012 06:48 AM
Andy
Can you send a "debug ccsip messages"
08-29-2012 07:07 AM
Hi, Thanks for comming back so quick.
I've attached a debug ccsip messages log there is a bit off ISDN activity in there as well
Im not on-site but i have a Soft phone connected to the system from my laptop.
I made a test call to my mobile without dialing 9 which went via the ISDN line and was succesful
I then made a test call dialing 9 first to my mobile and got the BT woman saying number not recognised
my mobile number ends in 434024
08-29-2012 07:14 AM
Received:
08-29-2012 07:35 AM
That was a quick fix, it does appear they authenticate our SIP-Trunks via IP and have the wrong public address listed on there system
08-29-2012 07:45 AM
Glad I could help. Thanks for the ratings and dont forget to keep coming back to the forum if you need any help.
