Community Member
Can not access CCM web site
Hi :
I have a CCM and version is 5.1 , I found I always can not open the web site of CCM when the server work about one month, but I can ping the address of CCM and the ip phone is ok, if I restart the CCM server then I can access the web site,why ?
VIP Super Bronze
Re: Can not access CCM web site
Your problem is likely to be tomcat service...
You do not need to restart callmanager...
Just go to your CLI..type
utils service restart Cisco Tomcat.
This could be happening as a result of memory leak/bug, I had similar problem with CCm5.1.3a (5.1.3-1000) and cisco TAC recommended that its abug with that version of CCM.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Community Member
thank you very much! I will try it tomorrow, yes, I found there is only 20M memery left but the CCM server has 2000M!
VIP Super Bronze
Ok.
Remember to rate my post if it helps! :)
linux always takes as much memory as it can to improve performance, that would not be any abnormal situation having little free memory
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
VIP Super Bronze
javalenc,
Can you help out here...
Tomcat wont start for this guy...Is there anything he should do or should he just log a TAC case...
Community Member
Looks like a TAC case to me. There are Linux sylog files that may provide an anwser. Access is via CLI to download the files. I do not have details of how to get these files TAC will have it.
I once had a problem on Unity Connection (also linux applience) where Tomac was dying. There where over problems and root cause turned out to be a bad disk and disk mirroring. CPU was spiking trying to mirror bad disk. Strange but true.
Community Member
unluckily,after I input utils service restart Cisco Tomcat in the CLI, it said:
service manager is running
service manager response list for list request is NULL
component is not running
Cisco Tomcat [NOTRUNNING]
I try to use : utils service start Cisco Tomcat , and it is the same result.It seemed that there has no tomcat.
My CCM version is 5.1.3 1000-12
How can I do ?
Community Member
You need to open a TAC case on this. This may be a defect. They will also give you directions for retrieving logs.
Another option is to upgrade, it is easy to do now with 5.x and above. The latest 5.1.x release as of today is 5.1(3c). 6.1.x is also recommended release if you decide to dive there.
the service is not running, so you cannot restart something that is not running
have you tried starting it??
javalenc
java
VIP Super Bronze
javalenc,
he tried starting tomcat from his post...
How can I do ?
Community Member
Very strange , I can access the website of ccm yesterday didn't reboot the ccm server, but I changed nothing !
284
