Can not call forward to broadcast hunt group
Hi there,
I`ve got a strange phenomenon since some weeks. I did some configuration changes in the past, which seem to have changed something in the correct call routing between to sites.
We have two Call Manager Express. Calls between these sites are made over WAN (not PSTN).
Site one has internal numbers from 100 to 199, site two has numbers from 300 to 399. These are the voip dial-peers:
Site one (172.16.100.3):
dial-peer voice 10 voip
preference 1
destination-pattern 3..
progress_ind setup enable 3
modem passthrough nse codec g711alaw
session target ipv4:172.16.101.1
incoming called-number .
voice-class codec 1
dtmf-relay h245-alphanumeric
fax rate disable
fax protocol pass-through g711alaw
no vad
Site two (172.16.101.1):
dial-peer voice 2 voip
preference 1
destination-pattern 1..
session target ipv4:172.16.100.3
voice-class codec 1
fax rate disable
no vad
The problem is, when I try to call forward a DN from site two (for example 301) to a Bradcast HuntGroup on site one (for example 199 with numbers 101 and 102), the call can`t be established. If I configure CFNA (12 seconds) you hear three rings and then nothing. The call doesn`t get quit, you just hear nothing.
The funny thing is, that if I configure a sequentiell HuntGroup with the same numbers, it works.
Also if I call from GSM or PSTN to number 301, the Call Forward to the Broadcast HuntGroup would work, but not internal over WAN?!
Could someone explain that behaviour?
Thanks in advance,
VoiceDealer
1 REPLY
Hi Jens,
What is your CME versions ? And which protocol(SCCP or SIP) are you using for phone registration ?
Manish
108
