10-09-2014 07:42 PM - edited 03-17-2019 12:30 AM
I can not call transfer. The issue seldom occured it.
Occurs once a month.
Then rises as high as 70% of VG memory.
And you can not use the Call Transfer.
It is resolved automatically memory falls after a few minutes.
What should I check?
10-09-2014 08:53 PM
Have you turn off all debug...just do 'u all' and then monitor.
And pls share o/p of below command when issue occurs.
show processor cpu history
Suresh
10-09-2014 09:23 PM
Dear,
Sorry the no memory issue and this is the CPU issue.
GW-1#sh proc cpu history
GW-1 05:04:10 PM Friday Sep 19 2014 KST
333332222222222333332222222222333333333322222222223333333333
100
90
80
70
60
50
40
30
20
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
4 4 4 4 4 5 4 4 41 47 4 4
332532337333343333633336334304433734469333354232828837322813
100
90
80
70 *
60 *
50 * * * * * * * * ** *
40 * * * * * * * * * ** * *
30 * * * * * * * * * ** * *
20 * * * * * * * * * ** * *
10 # # # # # # # *# #* ##** # *#
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
555455544444444443333333454344543444444444444445444444443333443444444455
101921296664531529715216003812148035655667765670332840555625136203225600
100
90
80
70
60
50 *********** * * * * ************* * ** ****
40 ******************* * *********************************** *************
30 ************************************************************************
20 ************************************************************************
10 ************************************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
GW-1#
GW-1#sh proc cpu | ex 0.00
CPU utilization for five seconds: 3%/1%; one minute: 3%; five minutes: 3%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
42 9275804 2323780 3991 0.63% 0.61% 0.61% 0 Per-Second Jobs
114 2553656 43857063 58 0.15% 0.06% 0.08% 0 IP Input
179 464 576368707 0 0.23% 0.21% 0.22% 0 HQF Shaper Backg
202 158136 583869 270 0.07% 0.04% 0.01% 0 AFW_application_
304 105584 1122127 94 0.07% 0.04% 0.02% 0 VOIP_RTCP
306 161932 1591957 101 0.07% 0.05% 0.05% 0 DSMP
315 321928 1379548 233 0.07% 0.08% 0.06% 0 CCH323_CT
328 328 193042330 0 0.07% 0.10% 0.08% 0 CH_GT96K Backgro
GW-1#sh version
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 25-Feb-09 23:13 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T10, RELEASE SOFTWARE (fc1)
GW-1 uptime is 3 weeks, 5 days, 19 hours, 52 minutes
System restarted at 21:11:08 KST Sat Aug 23 2014
System image file is "flash:c3845-adventerprisek9-mz.124-24.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3845 (revision 1.0) with 221184K/40960K bytes of memory.
Processor board ID
2 Gigabit Ethernet interfaces
124 Serial interfaces
4 Channelized/Clear E1/PRI ports
1 Virtual Private Network (VPN) Module
12 Voice FXO interfaces
2 Voice E & M interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
10-09-2014 09:13 PM
Along with the output requested by Suresh, send us the following:
1. Show version
2. Show flash
3. show memory dead
Also, if possible can you send us the output of Show process memory when the issue occurs
