Can not complete conference (CME)
hi..
I'm using CME 7.1
I can't do a conference call. The phone displays the message "Can  not complete
conference". But  I can do a conference call for  local number.
I can dial phone B and they answer, but when I press Conf soft  key, The phone displays
the message "Can not complete  conference".
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
dial-peer voice 8000 voip
description #avaya#
translation-profile outgoing profile-55
destination-pattern xxxx
voice-class codec 1
session target ipv4:x.x.x.x
no vad
Thanks for any help..
Re: Can not complete conference (CME)
hi,
have u enabled DSPs and registered them under the telephony service
Super Bronze
That bit of your config tells nothing; except that you have it configured to route calls to another PBX.
Which phones are you conferencing in, and from where?
What's the rest of your config?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi ..
This is some configuration.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol t38 nse ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
h323
  h225 h245-address on-connect
voice class codec 1
voice register global
dial-peer voice 888 voip
  translation-profile outgoing profile-19
destination-pattern 123[2-4]...
voice-class codec 1
no vad
telephony-service
video
max-ephones 30
max-dn 30
ip source-address 10.0.0.1 port 2000
timeouts interdigit 3
system message MyComp
url services http://10.0.0.2/voiceview/common/login.do
url authentication http://10.0.0.1/CCMCIP/authenticate.asp
load 7906 SCCP11.8-4-2S.loads
load 7911 SCCP11.8-4-2S.loads
load 7921 CP7921G-1.2.1
load 7937 apps37sccp.1-2-1-0.bin
load 7941 SCCP41.8-4-2S.loads
load 7942 SCCP42.8-4-2S.loads
load 7961 SCCP41.8-4-2S.loads
load 7962 SCCP42.8-4-2S.loads
time-zone 41
time-format 24
date-format dd-mm-yy
dialplan-pattern 1 20.. extension-length 4
voicemail 2030
max-conferences 8 gain -6
dn-webedit
time-webedit
transfer-system full-consult
fac standard
create cnf-files version-stamp 7960 Mar 31 2010 13:40:03
ephone-dn  1  dual-line
number 2010
pickup-group 2099
description Peter
name Peter
call-forward busy 2030
call-forward noan 2030 timeout 28
corlist incoming outside
ephone  1
no multicast-moh
mac-address 0064.CBDA.FF23
username "Peter" password 111111
speed-dial 1 2000 label "Receptionist"
type 7911
button  1:10
I try conferencing from Cisco to Avaya.
I want to use ad hoc conference (software based) because Connection to site (conference problem) using SIP and I am using PVDM2-48.
VIP Super Bronze
From your config, its obvoius that you have not configured conferencing. Below is a sample config of what you need to enable conferencing on your CCME router.
voice-card 0
dsp services dspfarm..............................use this to enable dsp farm sharing.
sccp local gig0/0...............................................enable sccp on appripriate interface..yours may be different from gig0/0
sccp ccm 10.10.0.1 identifier 1 version 7.0.............tell sccp what the ip address of your ccme router is (yours may be diff from 10.10.0.1)
sccp...................................................................enable skinny control protocol
sccp ccm group 1
bind interface GigabitEthernet0/0.10.......................use appriopriate interfcae
associate ccm 1 priority 1
associate profile 1 register conference
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2------------------------------------define maximun session that you need or your PVDM resource allow
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
associate application SCCP
telephony-service
sdspfarm units 5
sdspfarm tag 1 conference
conference hardware
ephone-template  1
conference drop-mode local
conference admin
softkeys seized  Endcall Redial Cfwdall Meetme Pickup Callback
softkeys connected  Hold Endcall Park Confrn Trnsfer Select Join ConfList RmLst
ephone-dn  15  octo-line
number 929.......................................use appripriate number for meet me conference
name ScotCarey Conference
conference meetme
ephone-dn  16  octo-line
number 111..........................................use appripriate number for adhoc conference
name SoftCarey AD-HOC COnferencing
conference ad-hoc
ephone-dn  24  dual-line
number 112.....................................use appripriate number for adhoc conference
conference ad-hoc
ephone-dn  25  dual-line
number 113
conference ad-hoc
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi..
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8.
codec g729r8
codec g729br8
shutdown
dspfarm profile 1 conference status is shudown. When  I try to no shut, it asked
"Please configure the maximum sessions for this profile and retry"
CME(config-dspfarm-profile)#maximum sessions ?
  <0-0>  Number of sessions assigned to this profile
I can't enter for maximum sessions.
VIP Super Bronze
Hi, what that means is that you do not have enough DSP resources. You can either add more PVDM or reduce the number of voice channels you have provisioned for the circuit. You can also reduce the codec types on the dspfarm profile to only the ones you want or need.
Super Bronze
Can you post a show diag so we can see what DSP/VICs you have?
Try removing G729r8 from the conference config, leaving the other g729 variants.
Aaron
For sh diag, please see attached.
I removed G729r8 from the conference config, but still "can not complete conference"
I'am using PVDM2-48. From cisco documentation, it said that PVDM2-48 it's not supported for SCCP Hardware based. So I try to configure using SIP software based (SIP: Configuring Conferencing Options on a Phone). Am I wrong using SIP software based?
Thanks..
This is capture for show voice dsp group all
sh voice dsp group all
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 24.3.2
  Max signal/voice channel: 16/16
  Max credits: 240
  num_of_sig_chnls_allocated: 16
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 240, reserved credits: 0
    Signaling channels allocated: 16
    Voice channels allocated: 0
    Credits used: 0
dsp 2:
  Max credits: 240
    Credits used: 0
dsp 3:
  Max credits: 240
  num_of_sig_chnls_allocated: 4
    Signaling channels allocated: 4
    Credits used: 0
DSP groups on slot 1:
This command is not applicable to slot 1
DSP groups on slot 2:
This command is not applicable to slot 2
  0 DSP resource allocation failure
how to read that I have / do not have enough DSP resources?
Hi everyone,
I have the same problem,
but when I've removed the "conference hardware" in the telephony service.
Everything works fine. Try to do it.
Now this is my question :
When we shall use the command "conference hardware" and whe we should not use it?
Best regards,
Antra
I have writen the "conference hardware" under telephony-services  and problem was solved.
Thanks iantra123
No conference hardware and
No conference hardware and all of a sudden everything is working like a charm!!
Awesome. Thanx. Removing the "conference hardware" worked for me as well.
Thanks iantra123, I had this
Thanks iantra123, I had this issue too, but I've did that you said and was resolved then. A company mate did an upgrade in a CME "CISCO2911/K9" chassis to version 8.6 and IOS 15.1(4)M7 (I don't know what version have before); after this upgrading conference stop working, but removing "CONFERENCE HARDWARE" was resolved.
Thanks a lot guy.
Hi everyone.
After begin I want to tell you that I´m a newby.
I have the same problem. I can make the calls mix (conference).  All telephones show in the screen "cannot complete conference" and put  the call on hold and open a new line.
I try removing the "conference hardware" and nothing.
I have an UC520.
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class custom-cptone leavetone
dualtone conference
  frequency 400 800
  cadence 400 50 200 50 200 50
voice class custom-cptone jointone
dualtone conference
  frequency 400 800
voice-card 0
ephone-template  1
softkeys hold  Join Newcall Resume Select
softkeys idle  Redial Newcall Cfwdall Gpickup Pickup Dnd Join RmLstC
softkeys seized  Endcall Redial Meetme Cfwdall Pickup
softkeys connected  Hold Endcall Trnsfer Confrn ConfList Join Park RmLstC Select
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 7.0
sccp
sccp ccm group 1
associate profile 1 register confprof1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
ephone  6
conference drop-mode creator
conference add-mode creator
conference admin
device-security-mode none
description Ulima
mac-address 0025.84A2.E98E
ephone-template 1
type 7942
button  1:6
TUC520#sh voice dsp group all
dsp 1:
  State: UP, firmware: 26.8.1
  Max credits: 240
  num_of_sig_chnls_allocated: 10
    Shared credits: 225, reserved credits: 0
    Signaling channels allocated: 10
    Voice channels allocated: 1
    Credits used (rounded-up): 15
    Voice channels:
      Ch01: voice port: 0/4/0, codec: g711ulaw, credits allocated: 15
dsp 2:
  Max credits: 240
  num_of_sig_chnls_allocated: 0
  Group: FLEX_GROUP_CONF, complexity: CONFERENCE
    Shared credits: 0, reserved credits: 240
    Codec: CONF_G729, maximum participants: 8
    Sessions per dsp: 2
Thanks to all
10914
