can not ping cisco router (as voice gateway ) from switch
Hi ,
My voice gateway is directly conected with the switch :
interface gi 1/0/22
Des -------- connected with Voice Gateway ---------
switchport access vlan 20         ( Vlan 20 is Voice Vlan)
switchport mode access
Roueter port config :
int gi 0/1
ip add 10.14.20.10 255.255.255.0
no shut
intervlan routing is working fine on l3 switch
But i can ping from switch to router and vise versa.
  • IP Telephony
1 REPLY
Hall of Fame Super Silver
Are you sourcing the ping from the voice vlan?
Do you have "ip routing" enabled on the switch?
Can you share your relevant config from the switch?
Chris
127
