Can not route incoming call to CCM
Hi everybody,
I have a Cisco CCM 6.1 cluster and 2 Cisco Voice Gateways. I try to make incoming call from PSTN to my IPPhone. But, it is not successful. Pls review my call flow:
PSTN----GW(10.149.80.253)---CCM (10.149.89.12/10.149.89.13)---0999
Cisco Voice Gateway Configuration:
voice translation-rule 4
rule 1 // /0\1/
voice translation-profile EditCallingIncoming
translate calling 4
voice translation-rule 3
rule 1 /^18001091/ /0999/
voice translation-profile 18001091
translate called 3
voice class codec 1
codec preference 1 g711alaw
interface Loopback0
ip address 10.149.80.253 255.255.255.255
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.149.80.253
dial-peer voice 100 pots
tone ringback alert-no-PI
description IN/OUT POTS
translation-profile incoming EditCallingIncoming
destination-pattern 0.T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
direct-inward-dial
port 7/0:D
dial-peer voice 201 voip
description IN/OUT VOIP
translation-profile outgoing 18001091
destination-pattern 1800T
voice-class codec 1
session target ipv4:10.149.89.13
incoming called-number .
dtmf-relay h245-signal h245-alphanumeric
dial-peer voice 202 voip
voice-class codec 1
session target ipv4:10.149.89.12
CCM Trace log:
/11/2012 15:55:38.243 CCM|H225Handler::SdlConnectionInd, rejecting the TCP connection from IP=10.149.80.253. Incoming H225 call on Port=1720, can't find this port in the registered H323 endpoints port list. |<CLID::StandAloneCluster><NID::10.149.89.12><CT::0,0,0,0.0><IP::><DEV::><LVL::Error><MASK::0100>
04/11/2012 15:55:38.445 CCM|H225Handler::SdlConnectionInd, rejecting the TCP connection from IP=10.149.80.253. Incoming H225 call on Port=1720, can't find this port in the registered H323 endpoints port list. |<CLID::StandAloneCluster><NID::10.149.89.12><CT::0,0,0,0.0><IP::><DEV::><LVL::Error><MASK::0100>
04/11/2012 15:55:39.270 CCM|H225Handler::SdlConnectionInd, rejecting the TCP connection from IP=10.149.80.253. Incoming H225 call on Port=1720, can't find this port in the registered H323 endpoints port list. |<CLID::StandAloneCluster><NID::10.149.89.12><CT::0,0,0,0.0><IP::><DEV::><LVL::Error><MASK::0100>
04/11/2012 15:55:39.849 CCM|H225Handler::SdlConnectionInd, rejecting the TCP connection from IP=10.149.80.253. Incoming H225 call on Port=1720, can't find this port in the registered H323 endpoints port list. |<CLID::StandAloneCluster><NID::10.149.89.12><CT::0,0,0,0.0><IP::><DEV::><LVL::Error><MASK::0100>
04/11/2012 15:55:45.381 CCM|H225Handler::SdlConnectionInd, rejecting the TCP connection from IP=10.149.80.253. Incoming H225 call on Port=1720, can't find this port in the registered H323 endpoints port list. |<CLID::StandAloneCluster><NID::10.149.89.12><CT::0,0,0,0.0><IP::><DEV::><LVL::Error><MASK::0100>
04/11/2012 15:55:45.741 CCM|H225Handler::SdlConnectionInd, rejecting the TCP connection from IP=10.149.80.253. Incomin
I tested to make local call to 0999, it is OK.
Anybody explain for me?
Thuc
Blue
Just to ask one point. What is the DN configured in CUCM you are calling from PSTN.
Is the partition of DN in Gateway CSS. Is h.323 Gateway  added in Cisco CUCM.
Send us debug isdn q931 of failed call.
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak,
This Configured DN is for IVR application. I tested local call for this DN, it is OK. And I make outgoing call via the GW properly as well. So, I don't think the issue in  ISDN connection. H.323 Gateway is added in Cisco CUCM.
Actually, the CSS of H.323 GW has one Translation Pattern ( Translation Pattern: XXXX, : Allowed, Calling Name Presentation : Allowed, Calling Search Space : Normal_CSS ). The Normal_CSS included 0999.
Any ideas?
Thuc
Hall of Fame Super Silver
Can you post "debug isdn q931" for this call?
Chris
288
