Can not send fax...showing Scheduled to be Sent
I am using RightFax 9.4 (Business Edition). The topology of the solution is PSTN/FAX-->VG-->CUCM via H.323-->RightFax
From the Fax server I am unable to send any fax. Using Fax uitity while sending fax it shows Scheduled to be Sent.
I am using SR140. In the Brooktrout I configured the CUCM as default  h.323 gateway. also in CUCM configured fax server as h.323 gatway. I am  suspecting that my VG configuration may have some problem.
I start wireshark on fax server and that is no activeties after Sent fax from FaxUtil.
1 ACCEPTED SOLUTION
Re: Can not send fax...showing Scheduled to be Sent
Hi Alexander,
Are you meaning that outgoing faxes are working in the following scenario ?
"PSTN --GW-sip-Rightfax server."
If you are facing issues with fax speed, did you try setting the speed to a lower value using the fax rate command? (you can use this under voice service voip or individual dial-peer)
Bala.
PS: Please rate useful posts. Please mark the thread as answered if the issue is resolved.
Hi Alexander,
A few questions to understand the issue better.
1. Any fax call is first established as a voice call. So, from your right  fax server, if you enter the number of a destination fax or phone, is  the destination end point ringing?
2. Are incoming faxes working?
3. Are outbound "voice" calls via the PSTN working ok?
4. If you think that the issue is your voice gateway, can you please post the following debugs for a fax call
debug fax relay t30 all-level-1
debug voip ccapi inout
debug voip vtsp all
debug voip rtp session nse
debug h225 q931
debug h225 asn1
debug h245 asn1
debug isdn q931 (if your PSTN is a PRI line)
along with the sh run of the gateway (after removing confidential information if any in the sh run)
5. Also please post the packet capture on the fax server.
Bala.
Hi, bsundar
Thanks for your answer.
1. Now i use scheme E1->GW->FAX. Without CCM. No, if I use FaxUtil
and call to my mobil number, the phone is not ringing, but i see on
wireshark, that installed in my Fax server, that there is RTP.
2. Incoming faxes are working
3. Ok
4. I think that this is GW problem, because i do not use CCM
Logs and packer capture are in link below
http://dl.dropbox.com/u/33041686/Debugs.rar
Hi Alexander,
Thanks a lot for the information and debugs.
Let me check it and get back to you.
Bala.
PS: Please rate helpful posts and mark the discussion as Answered when the issue is resolved.
Bsundar, thanks.
what router model and ios version are using ?
anyway try the bellow comands and make sure t38 is enabled
voice service pots
fax rate disable
voice service voip
fax protocol none
modem passthrough nse codec g711ulaw
also see the bellow discussion it might be helful foir your case
https://supportforums.cisco.com/message/3418715#3418715
if helpful Rate
Router - cisco 2921, ios - 15.1(3)T
Plz use the above commands and try it
Hi Alexander,
From the ISDN messages, we see that the PSTN is not even sending alerting. The gateway just receives ISDN call proceeding with progress indicators followed by an ISDN disconnect.
Is the destination number "84957847314" that you are calling valid?
I see this as a PSTN issue or a destination number issue.
Can you please try with another destination number?
Your fax configuration under the voip dial-peer 777 is correct.
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
*Aug 16 08:00:31.951: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x012D
    Called Party Number i = 0xA1, '84957847314'
*Aug 16 08:00:31.967: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0x812D
    Channel ID i = 0xA9839F
        Exclusive, Channel 31
*Aug 16 08:00:35.971: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x812D
    Progress Ind i = 0x8288 - In-band info or appropriate now available
*Aug 16 08:00:36.339: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x812D
    Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
*Aug 16 08:00:41.231: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x812D
    Cause i = 0x8390 - Normal call clearing
Bala.
PS:Please rate helpful posts. Please mark the question as Answered when the issue is resolved.
Hi, Bsundar,
The destination number "84957847314" is the fax in auto mode. If i call this number I will hear a fax beep.
I find anather number 84956461658 - the fax in auto mode, if you call this number, you hear fax beep.
Result status of Rightfax Util is "No answer of fax at Fax Number"
http://dl.dropbox.com/u/33041686/debug.txt - debug log
Now I connect GW to CCM with mgcp, incoming fax is OK. Outgoing - FaxUtil status - "Fax Number is busy". But fax is on auto mode.
And I can call to CCM internal DN.
Debug:
HQ#
*Aug 17 12:29:44.238: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x316502B8, Interface Type=6, Destination=, Mode=0x9,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=D0000000010e9fd4000000F500000005)
*Aug 17 12:29:44.238: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Aug 17 12:29:44.238: :cc_get_feature_vsa malloc success
*Aug 17 12:29:44.238:  cc_get_feature_vsa count is 1
*Aug 17 12:29:44.238: :FEATURE_VSA attributes are: feature_name:0,feature_time:830128872,feature_id:100
*Aug 17 12:29:44.238: //102/6BEED7788019/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
*Aug 17 12:29:44.238: //102/6BEED7788019/CCAPI/ccCallSetContext:
   Context=0x30005578
   Interface=0x2A7ED1E4, Interface Type=9, Destination=0.0.0.0, Mode=0x9,
   Subscriber Type Str=, FinalDestinationFlag=FALSE, Outgoing Dial-peer=0, Call Count On=TRUE,
*Aug 17 12:29:44.242: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Aug 17 12:29:44.242:  cc_get_feature_vsa count is 2
*Aug 17 12:29:44.242: :FEATURE_VSA attributes are: feature_name:0,feature_time:830128648,feature_id:101
*Aug 17 12:29:44.242: //103/6BEED7788019/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=9, FlowMode=1
*Aug 17 12:29:44.242: //103/6BEED7788019/CCAPI/ccCallSetContext:
   Context=0x30003F78
*Aug 17 12:29:44.242: //103/6BEED7788019/CCAPI/cc_api_call_connected:
   Interface=0x2A7ED1E4, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Aug 17 12:29:44.242: //102/6BEED7788019/CCAPI/cc_api_call_proceeding:
   Interface=0x316502B8, Progress Indication=NULL(0)
*Aug 17 12:29:44.242: //102/6BEED7788019/CCAPI/cc_api_call_connected:
   Interface=0x316502B8, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
*Aug 17 12:29:44.242: //102/6BEED7788019/CCAPI/ccCallModify:
   Nominator=0x1000, Params=0x2B9F7E68, Call Id=102
*Aug 17 12:29:44.242: //102/6BEED7788019/CCAPI/ccCallReportDigits:
   (callID=0x66, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Call Id=102
*Aug 17 12:29:44.242: //102/6BEED7788019/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x316502B8, callID=0x66, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
   Enabled=TRUE, Disposition=0x0, Interface=0x316502B8, Call Id=102
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
*Aug 17 12:29:44.242: //102/6BEED7788019/CCAPI/ccConferenceCreate:
   (confID=0x2B9F8084, callID1=0x66, gcid=0-0-0-0, tag=0x0)
*Aug 17 12:29:44.242: //103/6BEED7788019/CCAPI/ccConferenceCreate:
   (confID=0x2B9F8084, callID2=0x67, gcid=0-0-0-0, tag=0x0)
   Conference Id=0x2B9F8084, Call Id1=102, Call Id2=103, Tag=0x0
*Aug 17 12:29:44.242: //102/6BEED7788019/CCAPI/cc_api_bridge_done:
   Conference Id=0x26, Source Interface=0x316502B8, Source Call Id=102,
   Destination Call Id=103, Disposition=0x0, Tag=0xFFFFFFFF
*Aug 17 12:29:44.242: //103/6BEED7788019/CCAPI/cc_api_bridge_done:
   Conference Id=0x26, Source Interface=0x2A7ED1E4, Source Call Id=103,
   Destination Call Id=102, Disposition=0x0, Tag=0x0
*Aug 17 12:29:44.242: //102/6BEED7788019/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x26, Destination Call Id=103)
   Call Entry(Conference Id=0x26, Destination Call Id=102)
*Aug 17 12:29:44.242: //102/6BEED7788019/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2A7ED1E4, Destination Call Id=103, Source Call Id=102,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
*Aug 17 12:29:44.242: //103/6BEED7788019/CCAPI/cc_api_caps_ind:
   Destination Interface=0x316502B8, Destination Call Id=102, Source Call Id=103,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
*Aug 17 12:29:44.242: //103/6BEED7788019/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5071)
*Aug 17 12:29:44.242: //102/6BEED7788019/CCAPI/cc_api_caps_ack:
*Aug 17 12:29:44.242: //102/6BEED7788019/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x316502B8, Call Id=102
*Aug 17 12:29:44.246: //102/6BEED7788019/CCAPI/cc_api_voice_mode_event:
   Call Id=102
   Call Entry(Context=0x30005578)
*Aug 17 12:29:44.246: //102/6BEED7788019/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x26, Call Id1=102, Call Id2=103
*Aug 17 12:29:44.246: //102/6BEED7788019/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms)
   Call Entry(Inter Digit Timeout=4000(ms), Initial Digit Timeout=4000(ms))
*Aug 17 12:29:44.246: //102/6BEED7788019/CCAPI/ccRestartDigitTimeoutMsec:
   Digit Timeout=0, Call Id=102
*Aug 17 12:29:44.246: //102/6BEED7788019/CCAPI/ccCallReportDigits:
*Aug 17 12:29:44.246: //102/6BEED7788019/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
*Aug 17 12:29:44.246: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0005
    Sending Complete
    Bearer Capability i = 0x8090A3
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Calling Party Number i = 0x0083, N/A
        Plan:Unknown, Type:Unknown
    Called Party Number i = 0xA0, '84956461658'
        Plan:Unknown, Type:National
*Aug 17 12:29:48.246: //102/6BEED7788019/CCAPI/cc_handle_inter_digit_timer:
   Generate inter-digit timeout CC_EV_CALL_DIGIT_END event
*Aug 17 12:29:48.258: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0005
    Sending Complete
        Standard = CCITT
*Aug 17 12:29:48.270: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8005
*Aug 17 12:29:48.658: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8005
*Aug 17 12:29:53.454: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8005
*Aug 17 12:30:00.670: //102/6BEED7788019/CCAPI/ccCallReportDigits:
   (callID=0x66, digit_event=0x0, enable=FALSE, consume=FALSE)
*Aug 17 12:30:00.670: //102/6BEED7788019/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x316502B8, callID=0x66, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
*Aug 17 12:30:00.670: //103/6BEED7788019/CCAPI/ccGetCallStatistics:
   Call Stats=0x2ABA92DC, Call Id=103
*Aug 17 12:30:00.670: //102/6BEED7788019/CCAPI/ccConferenceDestroy:
   Conference Id=0x26, Tag=0x0
*Aug 17 12:30:00.670: //102/6BEED7788019/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=103, Disposition=0x0, Tag=0x0
*Aug 17 12:30:00.670: //103/6BEED7788019/CCAPI/cc_api_bridge_drop_done:
*Aug 17 12:30:00.670: //102/6BEED7788019/CCAPI/cc_generic_bridge_done:
*Aug 17 12:30:00.670: //102/6BEED7788019/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Aug 17 12:30:00.670: //102/6BEED7788019/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Aug 17 12:30:00.670: //103/6BEED7788019/CCAPI/ccCallDisconnect:
*Aug 17 12:30:00.678: //103/6BEED7788019/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2A7ED1E4, Tag=0x0, Call Id=103,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Aug 17 12:30:00.678: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Aug 17 12:30:00.678: :cc_free_feature_vsa freeing 317AC200
*Aug 17 12:30:00.678:  vsacount in free is 1
*Aug 17 12:30:00.686: //102/6BEED7788019/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x316502B8, Tag=0x0, Call Id=102,
*Aug 17 12:30:00.686: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Aug 17 12:30:00.686: :cc_free_feature_vsa freeing 317AC2E0
*Aug 17 12:30:00.686:  vsacount in free is 0
*Aug 17 12:30:00.686: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8  callref = 0x0005
*Aug 17 12:30:00.698: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x8005
Hi Alexander,
Thanks a lot for the detailed logs.
The issue is not with H323/MGCP/fax settings on the gateway.
If we look at the ISDN traces, we can see that the far end is not sending an alerting. Instead the far end sends a disconnect.
We see the same behaviour with calls to  984957847314  on the debugs sent yesterday.
So, again it is not your configuration that is the issue. It is an issue on the far-end (or PSTN)
Bala.
    Sending Complete
        Standard = CCITT
*Aug 17 12:29:53.454: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref =0x8005
Hi, Bsundar.
I connect now GW to Fax Server with SIP.
When I sent outgoing fax to 84957847314 I can see T.38 wireshark, result: FaxUtil status - transmission error.
I change will try to change fax rate on Fax Server Brooktrout to 9600 - bad result, 12000 - good result on third attempt, 14400 - bad result. I now I cant cant sent fax on any fax rate - transmission error result.
Hi, Bsundar.
Please, look last post
That is all OK now, the faxes are send OK. The connection scheme - GW-sip-Rightfax server. Transmission error status says that may be fax rate is very fast.
Hi Alexander,
Bala.
Yes, outgoing faxes are working in the following scenario.
Now is all OK
4112
