Can not setup call to fax machine
Hi     There
We are using CUCM7.1(3), and try to integrate a fax server in the CUCM, call flow like this Fax server->CUCM trunk->h323 gateway to PABX->fax machine
there are 2 fax numbers, for example 12345 and 54321, send fax to 12345 always works, but send fax to 54321, it only worked once. I run the wireshark to check, it shows when the fax sever try to setup the logical link with CUCM, the CUCM released the call due to the most hated casue code 47 - resouces unavailable, unspecified.
anyone have suggestion for this problem? it quite strange that it works for one number but does not work for another
Can you add the wireshark trace?
Are Numbers 12345 e 54321 configured in tha fax server or in the fax machine?
Is the fax server SIP or H.323?
Is the Fax machine connected to an FXS extension?
Regards?
Hi        Daniele
The fax numbers are configured in the fax machine
The fax server is using h323
The fax machines are connected to Ericsson PABX system
After the weekend, the connection between fax server and the fax machine can be setup, it is wierd since we did nothing.
the problem is the terminal capability set can not be negociated properly between fax server and CUCM, the CUCM only reply the TCS with g711u codec, and after the master/slave negociation, the logical channel was closed
please see the attachment for the wireshark graph
Does CUCM use the same H.323 trunk to PBX in both cases?
What is the H.323 gateway? Can you add the config?
Regards.
Yes, the CUCM use the same h323 trunk to PBX in both cases
Here is the configuration for the gateway
controller e1 0/0/0
  pri-group timeslots 1-31
  trunk-group PABC-QSIG timeslots 1-31
trunk group PABX-QSIG
  hunt-scheme round-robin
Interface s 0/0/0:15
  isdn switch-type primary-qsig
voice-port 0/0/0:15
  echo-cancel coverage 32
  bearer-cap speech
dial-peer voice 100 pots
  trunkgroup PABX-QSIG
  destination-pattern [2-9]....
  direct-inward-dial
  forward-digit all
  progress-ind setup enable 3
  progress-ind progress enable 8
  progress-ind connect enable 8
and interesting thing is when I tried again today, it even did not have the connection setup
346
