Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Can not transfer data between Dial Up connection.
Hi All,
I want to create a connection between A & B cisco 1841 router. We have completed the configuration. When start a connection from  A to B or B to A connection was established.But in 2-3 second connection goes down wihout any ping was sent.
Topology and configuration was attaced. How can we able to transfer data between these locations. (we can not ping)
Aim is using dialup connection for backup.
Topology;
Config C::::::::::::::::::::::::::
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
controller E1 0/2/1        //connectted to Telc0//
pri-group timeslots 1-31
controller E1 0/3/0          //connected to Nortel //
interface Serial0/2/1:15
no ip address
encapsulation hdlc
isdn incoming-voice modem
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn protocol-emulate network
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/3/0:15
voice-port 0/2/1:15
Config A :::::::::::::::::::::::::::::
interface Dialer2
description Dial Backup
bandwidth 28
ip address 1.1.1.2 255.255.255.252
no ip redirects
no ip proxy-arp
ip authentication mode eigrp 100 md5
ip authentication key-chain eigrp 100 atmauth2
dialer pool 2
dialer idle-timeout 600
dialer string XXXXX
dialer-group 1
1 REPLY
Re: Can not transfer data between Dial Up connection.
A To B :  (debugs)
Mar  2 13:50:32.082 ist: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x7759
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98385
                Exclusive, Channel 5
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x2180, 'XXXXXXX'
                Plan:ISDN, Type:National
        Called Party Number i = 0x81, 'XXXXx'
                Plan:ISDN, Type:Unknown
        Sending Complete
Mar  2 13:50:32.082 ist: ISDN Se0/3/0:15 Q931: Received SETUP  callref = 0xF759 callID = 0x0165 switch = primary-net5 interface = Network
Mar  2 13:50:32.086 ist: ISDN Se0/2/1:15 Q931: Applying typeplan for sw-type 0x12 is 0x2 0x1, Calling num xxxxxxxx
Mar  2 13:50:32.086 ist: ISDN Se0/2/1:15 Q931: Sending SETUP  callref = 0x00F6 callID = 0x808B switch = primary-net5 interface = User
Mar  2 13:50:32.086 ist: ISDN Se0/3/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0xF759
ETEPEPRIGW3#
Mar  2 13:50:32.086 ist: ISDN Se0/2/1:15 Q931: TX -> SETUP pd = 8  callref = 0x00F6
                Standard = CCITT
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x2180, 'xxxxxxxx'
        Called Party Number i = 0x81, 'xxxxx'
Mar  2 13:50:32.238 ist: ISDN Se0/2/1:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x80F6
ETEPEPRIGW3#
Mar  2 13:50:32.486 ist: ISDN Se0/2/1:15 Q931: RX <- ALERTING pd = 8  callref = 0x80F6
        Progress Ind i = 0x8482 - Destination address is non-ISDN
Mar  2 13:50:32.490 ist: ISDN Se0/3/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xF759
        Facility i = 0x9FAA068001018201018B0100A109020200F30201018000
                Protocol Profile =  Networking Extensions
                0x010182
                0x01018B
                0x0100
                0xA109020200F30201018000
                Component = Invoke component, Unsupported operation
        Progress Ind i = 0x8182 - Destination address is non-ISDN
ETEPEPRIGW3#
Mar  2 13:50:35.138 ist: ISDN Se0/2/1:15 Q931: RX <- CONNECT pd = 8  callref = 0x80F6
Mar  2 13:50:35.138 ist: %ISDN-6-CONNECT: Interface Serial0/2/1:30 is now connected to xxxxxxx N/A
Mar  2 13:50:35.138 ist: ISDN Se0/2/1:15 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x00F6
Mar  2 13:50:35.138 ist: %ISDN-6-CONNECT: Interface Serial0/3/0:4 is now connected to xxxxxxx N/A
ETEPEPRIGW3#
Mar  2 13:50:35.138 ist: ISDN Se0/3/0:15 Q931: TX -> CONNECT pd = 8  callref = 0xF759
Mar  2 13:50:35.158 ist: ISDN Se0/3/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x7759
ETEPEPRIGW3#
Mar  2 13:50:40.142 ist: ISDN Se0/2/1:15 Q931: RX <- FACILITY pd = 8  callref = 0x80F6
        Facility i = 0x91A1120201F9020122300AA1053003020101820100
                Protocol Profile = Remote Operations Protocol
                0xA1120201F9020122300AA1053003020101820100
                        Invoke Id = 65529
                        Operation = AOCDChargingUnit
Mar  2 13:50:40.142 ist: ISDN Se0/3/0:15 Q931: TX -> FACILITY pd = 8  callref = 0xF759
                        Invoke Id = 65529
ETEPEPRIGW3#
Mar  2 13:50:41.614 ist: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/3/0:4, changed state to up
ETEPEPRIGW3#
Mar  2 13:51:06.229 ist: ISDN Se0/3/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x7759
        Cause i = 0x8190 - Normal call clearing
Mar  2 13:51:06.229 ist: %ISDN-6-DISCONNECT: Interface Serial0/3/0:4  disconnected from xxxxxxxx , call lasted 31 seconds
Mar  2 13:51:06.229 ist: ISDN Se0/3/0:15 Q931: TX -> RELEASE pd = 8  callref = 0xF759
Mar  2 13:51:06.229 ist: %ISDN-6-DISCONNECT: Interface Serial0/2/1:30  disconnected from xxxxx , call lasted 31 seconds
ETEPEPRIGW3#
Mar  2 13:51:06.229 ist: ISDN Se0/2/1:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x00F6
        Cause i = 0x8090 - Normal call clearing
Mar  2 13:51:06.253 ist: ISDN Se0/3/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x7759
Mar  2 13:51:06.541 ist: ISDN Se0/2/1:15 Q931: RX <- RELEASE pd = 8  callref = 0x80F6
        Facility i = 0x91A11202010A020122300AA1053003020101820101
                0xA11202010A020122300AA1053003020101820101
                        Invoke Id = 10
Mar  2 13:51:06.541 ist: ISDN Se0/2/1:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x00F6
Mar  2 17:57:16.346 ist: ISDN Se0/2/1:15 Q931: RX <- ALERTING pd = 8  callref = 0x8101
Mar  2 17:57:16.346 ist: ISDN Se0/3/0:15 Q931: TX -> ALERTING pd = 8  callref = 0xFB59
        Facility i = 0x9FAA068001018201018B0100A109020201020201018000
                0x010182
                0x01018B
                0x0100
                0xA109020201020201018000
                Standard = CCITT
        Sending Complete
ETEPEPRIGW3#
                Standard = CCITT
ETEPEPRIGW3#
                0x010182
                0x01018B
                0x0100
ETEPEPRIGW3#
ETEPEPRIGW3#
ETEPEPRIGW3#
                        Invoke Id = 65529
                        Invoke Id = 65529
ETEPEPRIGW3#
ETEPEPRIGW3#
ETEPEPRIGW3#
                        Invoke Id = 10
                0x010182
                0x01018B
                0x0100
331
