Community Member
Can not view Caller ID
Hello to all ,
I have a publisher, Subscriber recently added both have 7.1.5.30000-1 version. In the new building I have a Cisco 3925, what is happening is that when making a call from outside can not see who perform, does not display the caller ID
Everyone's tags (4)
Hall of Fame Super Gold
Please give full details about the configuration, phone lines type, protocols, etc.
Community Member
router#sh call active voice br
: ms. () + pid:
  dur hh:mm:ss tx:/ rx:/
IP : rtt:
  delay://ms
media inactive detected: media cntrl rcvd: timestamp:
long duration call detected: long duration call duration : timestamp:
  MODEMPASS buf:/ loss /
   last s dur:/s
FR [int dlci cid] vad: dtmf: seq:
  (payload size)
ATM [int vpi/vci cid] vad: dtmf: seq:
  (payload size)
Tele (callID) [channel_id] tx://ms noise: acom: i/o:/ dBm
  MODEMRELAY info:// xid:/ total://
         speeds(bps): local / remote /
Proxy :
bw: / codec:
  tx:
rx:
Telephony call-legs: 1
SIP call-legs: 0
H323 call-legs: 1
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 2
13E4 : 262 687516410ms.1 (09:47:53.748 BUE Fri Jun 1 2012) +-1 pid:1 Answer 1163974628 connected
dur 00:00:00 tx:0/0 rx:0/0
Tele 0/1/0:0 (262) [0/1/0.1] tx:0/0/0ms None noise:0 acom:0  i/0:0/0 dBm
13E4 : 263 687516410ms.2 (09:47:53.748 BUE Fri Jun 1 2012) +-1 pid:500 Originate 4460 connecting
IP 0.0.0.0:0 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 pre-ietf TextRelay: off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long duration call duration:n/a timestamp:n/a
SIP call-legs: 0
H323 call-legs: 1
SCCP call-legs: 0
Total call-legs: 2
Community Member
The messagge is FROM UNKNOWN NUMBER ; but if I called to the number 5299 4460 ( INT 4460 ) via my CELL
1163974628 and I was see the caller ID ( please refer to the output )
Re: Can not view Caller ID
Sometime telco doesn't deliver caller ID. You can check "debug isdn q931" with "term mon".
Community Member
Paolo , i have E1 R2 , what`s the correct debug ?
controller E1 0/1/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
  country argentina
description Enlace PSTN XXXX XXXX
No, for E1 R2 use 'debug vpm signal'.
Community Member
router#debug vpm s
Jun  1 15:08:17.519 BUE: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2417340416 1500 bytes is out-of-order; expected seq:2417310008. Reason: TCP reassembly queue overflow - session 10.170.0.250:50644 to 204.2.222.17:80ignal
Voice Port Module signaling debugging is enabled
pcolon-router#sh debug
Voice Port Module signaling debugging is on
outer#
Jun  1 15:08:27.903 BUE: htsp_process_event: [0/1/0:0(2), R2_Q421_OG_ANSWER, E_DSP_SIG_1100]
Jun  1 15:08:27.903 BUE: r2_q421_ic_clr_bwd(0/1/0:0(2)) Rx CLEAR BWD
Jun  1 15:08:27.903 BUE: htsp_timer - 7000 msec
Jun  1 15:08:29.371 BUE: htsp_timer_stop3
Jun  1 15:08:29.387 BUE: htsp_process_event: [0/1/0:0(2), R2_Q421_OG_CLR_BWD, E_HTSP_RELEASE_REQ]
Jun  1 15:08:29.387 BUE: r2_q421_null_release(0/1/0:0(2)) E_HTSP_RELEASE_REQ
Jun  1 15:08:29.407 BUE: htsp_process_event: [0/1/0:0(2), R2_Q421_OG_CLR_BWD, E_DSP_SIG_1000]
Jun  1 15:08:29.407 BUE: r2_q421_clr_bwd_idle(0/1/0:0(2)) Rx IDLE
Jun  1 15:08:29.407 BUE: htsp_timer_stop
Jun  1 15:08:29.407 BUE: r2_q421_clr_bwd_idle(0/1/0:0(2)) Tx IDLEvnm_dsp_set_sig_state:[R2 Q.421 0/1/0:0(2)] set signal state = 0x8
Jun  1 15:08:29.407 BUE: r2_reg_channel_disconnected(0/1/0:0(2))
Jun  1 15:08:29.407 BUE: r2_reg_process_event: [0/1/0:0(2), R2_REG_CONNECTED, E_R2_REG_DISCONNECT(91)]
Jun  1 15:08:29.407 BUE: r2_reg_disconnect_idle(0/1/0:0(2))
Jun  1 15:08:29.407 BUE: r2_reg_timer_stop(0/1/0:0(2))
Jun  1 15:08:50.043 BUE: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1186044640 211 bytes is out-of-order; expected seq:1186025975. Reason: TCP reassembly queue overflow - session 10.170.0.250:62345 to 65.55.69.140:80
Jun  1 15:09:04.487 BUE: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2418840814 1500 bytes is out-of-order; expected seq:2418821990. Reason: TCP reassembly queue overflow - session 10.170.0.250:54341 to 65.55.69.140:80
Jun  1 15:09:17.139 BUE: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2054942754 1420 bytes is out-of-order; expected seq:2054919498. Reason: TCP reassembly queue overflow - session 10.170.0.250:51804 to 210.173.215.16:80
Jun  1 15:09:29.119 BUE: htsp_timer_stop3
Jun  1 15:09:29.135 BUE: htsp_process_event: [0/1/0:0(13), R2_Q421_OG_ANSWER, E_HTSP_RELEASE_REQ]
Jun  1 15:09:29.135 BUE: r2_q421_clr_fwd(0/1/0:0(13)) E_HTSP_RELEASE_REQ
Jun  1 15:09:29.135 BUE: r2_reg_channel_disconnected(0/1/0:0(13))
Jun  1 15:09:29.135 BUE: r2_q421_clr_fwd(0/1/0:0(13)) Tx CLEAR FWDvnm_dsp_set_sig_state:[R2 Q.421 0/1/0:0(13)] set signal state = 0x8
Jun  1 15:09:29.135 BUE: htsp_timer - 1000 msec
Jun  1 15:09:29.135 BUE: r2_reg_process_event: [0/1/0:0(13), R2_REG_CONNECTED, E_R2_REG_DISCONNECT(91)]
Jun  1 15:09:29.135 BUE: r2_reg_disconnect_idle(0/1/0:0(13))
Jun  1 15:09:29.135 BUE: r2_reg_timer_stop(0/1/0:0(13))
Jun  1 15:09:29.195 BUE: htsp_process_event: [0/1/0:0(13), R2_Q421_OG_CLR_FWD, E_DSP_SIG_1000]
Jun  1 15:09:29.195 BUE: r2_q421_clr_fwd_idle(0/1/0:0(13)) Rx IDLE
Jun  1 15:09:29.195 BUE: htsp_timer_stop
Jun  1 15:09:29.195 BUE: r2_q421_clr_fwd_idle(0/1/0:0(13)) Tx IDLEvnm_dsp_set_sig_state:[R2 Q.421 0/1/0:0(13)] set signal state = 0x8
Jun  1 15:09:29.195 BUE: r2_reg_channel_disconnected(0/1/0:0(13))
Jun  1 15:09:29.195 BUE: r2_reg_process_event: [0/1/0:0(13), R2_REG_IDLE, E_R2_REG_DISCONNECT(91)]
Jun  1 15:09:29.195 BUE: r2_reg_disconnect_idle(0/1/0:0(13))
Jun  1 15:09:29.195 BUE: r2_reg_timer_stop(0/1/0:0(13))
Jun  1 15:09:41.483 BUE: htsp_process_event: [0/1/0:0(1), R2_Q421_IDLE, E_DSP_SIG_0000]
Jun  1 15:09:41.483 BUE: r2_q421_ic_seize(0/1/0:0(1)) Rx SEIZURE
Jun  1 15:09:41.483 BUE: r2_reg_start_digit_collection(0/1/0:0(1))
Jun  1 15:09:41.483 BUE: r2_q421_ic_seize(0/1/0:0(1)) Tx SEIZE ACK (with 100ms delay)vnm_dsp_set_sig_state:[R2 Q.421 0/1/0:0(1)] set signal state = 0x8vnm_dsp_set_sig_state:[R2 Q.421 0/1/0:0(1)] set signal state = 0xC
Jun  1 15:09:41.483 BUE: htsp_timer - 2000 msec
Jun  1 15:09:41.483 BUE: r2_reg_process_event: [0/1/0:0(1), R2_REG_IDLE, E_R2_REG_START_COLLECTION(94)]
Jun  1 15:09:41.483 BUE: r2_reg_start_collecting(0/1/0:0(1))
Jun  1 15:09:41.483 BUE: r2_reg_timer_stop(0/1/0:0(1))
Jun  1 15:09:41.483 BUE: htsp_process_event: [0/1/0:0(1), R2_Q421_IC_SEIZE, E_HTSP_SETUP_ACK]
Jun  1 15:09:41.483 BUE: r2_q421_ic_setup(0/1/0:0(1)) E_HTSP_SETUP_ACK
Jun  1 15:09:41.483 BUE: htsp_timer_stop
Jun  1 15:09:41.483 BUE: r2_reg_offhook(0/1/0:0(1))
Jun  1 15:09:41.483 BUE: r2_reg_process_event: [0/1/0:0(1), R2_REG_COLLECTING, E_R2_REG_OFFHOOK(95)]
Jun  1 15:09:41.483 BUE: r2_reg_ic_offhook(0/1/0:0(1))
Jun  1 15:09:41.483 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_IDLE R2 Got Event R2_START
Jun  1 15:09:41.639 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='4'
Jun  1 15:09:41.639 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_PRE_CALLERID R2 Got Event 4
Jun  1 15:09:41.639 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '5'
Jun  1 15:09:41.751 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:41.751 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event R2_TONE_OFF
Jun  1 15:09:41.751 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:41.859 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='1'
Jun  1 15:09:41.859 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event 1
Jun  1 15:09:41.859 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '5'
Jun  1 15:09:41.971 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:41.971 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event R2_TONE_OFF
Jun  1 15:09:41.971 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:42.079 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='1'
Jun  1 15:09:42.079 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event 1
Jun  1 15:09:42.079 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '5'
Jun  1 15:09:42.187 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:42.187 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event R2_TONE_OFF
Jun  1 15:09:42.187 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:42.299 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='1'
Jun  1 15:09:42.299 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event 1
Jun  1 15:09:42.299 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '5'
Jun  1 15:09:42.407 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:42.407 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event R2_TONE_OFF
Jun  1 15:09:42.407 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:42.519 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='6'
Jun  1 15:09:42.519 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event 6
Jun  1 15:09:42.519 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '5'
Jun  1 15:09:42.631 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:42.631 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event R2_TONE_OFF
Jun  1 15:09:42.631 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:42.739 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='3'
Jun  1 15:09:42.739 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event 3
Jun  1 15:09:42.739 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '5'
Jun  1 15:09:42.851 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:42.851 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event R2_TONE_OFF
Jun  1 15:09:42.851 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:42.959 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='9'
Jun  1 15:09:42.959 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event 9
Jun  1 15:09:42.959 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '5'
Jun  1 15:09:43.071 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:43.071 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event R2_TONE_OFF
Jun  1 15:09:43.071 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:43.179 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='7'
Jun  1 15:09:43.179 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event 7
Jun  1 15:09:43.179 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '5'
Jun  1 15:09:43.287 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:43.287 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event R2_TONE_OFF
Jun  1 15:09:43.287 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:43.399 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='2'
Jun  1 15:09:43.399 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event 2
Jun  1 15:09:43.399 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '5'
Jun  1 15:09:43.507 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:43.507 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event R2_TONE_OFF
Jun  1 15:09:43.507 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:43.619 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='6'
Jun  1 15:09:43.619 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event 6
Jun  1 15:09:43.619 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '5'
Jun  1 15:09:43.731 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:43.731 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event R2_TONE_OFF
Jun  1 15:09:43.731 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:43.839 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='5'
Jun  1 15:09:43.839 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event 5
Jun  1 15:09:43.839 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '5'
Jun  1 15:09:43.951 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:43.951 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event R2_TONE_OFF
Jun  1 15:09:43.951 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:44.059 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='0'
Jun  1 15:09:44.059 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event 10
Jun  1 15:09:44.059 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '5'
Jun  1 15:09:44.171 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:44.171 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event R2_TONE_OFF
Jun  1 15:09:44.171 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:44.279 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='*'
Jun  1 15:09:44.279 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CALLERID R2 Got Event 15
Jun  1 15:09:44.279 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '1'
Jun  1 15:09:44.387 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:44.387 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_COLLECT_DNIS R2 Got Event R2_TONE_OFF
Jun  1 15:09:44.387 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:44.499 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='4'
Jun  1 15:09:44.499 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_COLLECT_DNIS R2 Got Event 4
Jun  1 15:09:44.499 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '1'
Jun  1 15:09:44.607 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:44.607 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_COLLECT_DNIS R2 Got Event R2_TONE_OFF
Jun  1 15:09:44.607 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:44.719 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='6'
Jun  1 15:09:44.719 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_COLLECT_DNIS R2 Got Event 6
Jun  1 15:09:44.719 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '1'
Jun  1 15:09:44.827 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:44.827 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_COLLECT_DNIS R2 Got Event R2_TONE_OFF
Jun  1 15:09:44.827 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:44.939 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='0'
Jun  1 15:09:44.939 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_COLLECT_DNIS R2 Got Event 10
Jun  1 15:09:44.939 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '1'
Jun  1 15:09:45.051 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:45.051 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_COLLECT_DNIS R2 Got Event R2_TONE_OFF
Jun  1 15:09:45.051 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:45.159 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='*'
Jun  1 15:09:45.159 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_COLLECT_DNIS R2 Got Event 15
Jun  1 15:09:45.159 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '3'
Jun  1 15:09:45.271 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:45.271 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CATEGORY R2 Got Event R2_TONE_OFF
Jun  1 15:09:45.271 BUE: Enter r2_comp_category
Jun  1 15:09:45.271 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:45.379 BUE: htsp_digit_ready_up(0/1/0:0(1)): Rx digit='1'
Jun  1 15:09:45.379 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_CATEGORY R2 Got Event 1
Jun  1 15:09:45.379 BUE: Enter r2_comp_category
Jun  1 15:09:45.379 BUE:  R2 Event : 1
Jun  1 15:09:45.379 BUE:  ####### collect_call_enable = 0
Jun  1 15:09:45.379 BUE: ######## Not Sending B7 ##################
Jun  1 15:09:45.379 BUE: r2_reg_event_proc(0/1/0:0(1)) ADDR_INFO_COLLECTED (DNIS=4460, ANI=1163972650)
Jun  1 15:09:45.379 BUE: r2_reg_process_event: [0/1/0:0(1), R2_REG_COLLECTING, E_R2_REG_ADDR_COLLECTED(89)]
Jun  1 15:09:45.379 BUE: r2_reg_ic_addr_collected(0/1/0:0(1))htsp_switch_ind
Jun  1 15:09:45.471 BUE: htsp_dialing_done(0/1/0:0(1))
Jun  1 15:09:45.471 BUE: htsp_process_event: [0/1/0:0(1), R2_Q421_IC_WAIT_ANSWER, E_HTSP_SETUP_ACK]
Jun  1 15:09:45.471 BUE: r2_q421_ic_setup_ack(0/1/0:0(1)) E_HTSP_SETUP_ACK
Jun  1 15:09:45.471 BUE: r2_reg_switch(0/1/0:0(1))
Jun  1 15:09:45.471 BUE: r2_reg_process_event: [0/1/0:0(1), R2_REG_WAIT_FOR_SWITCH, E_R2_REG_SWITCH(96)]
Jun  1 15:09:45.471 BUE: r2_reg_ic_switched(0/1/0:0(1))
Jun  1 15:09:45.471 BUE: htsp_process_event: [0/1/0:0(1), R2_Q421_IC_WAIT_ANSWER, E_HTSP_PROCEEDING]
Jun  1 15:09:45.475 BUE: htsp_process_event: [0/1/0:0(1), R2_Q421_IC_WAIT_ANSWER, E_DSP_SIG_0000]htsp_alert_notify
Jun  1 15:09:45.479 BUE: r2_reg_event_proc(0/1/0:0(1)) ALERTING RECEIVED
Jun  1 15:09:45.479 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_WAIT_REMOTE_ALERT R2 Got Event R2_ALERTING
Jun  1 15:09:45.479 BUE: rx R2_ALERTING in r2_comp_wait_remote_alert
Jun  1 15:09:45.479 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '6'
Jun  1 15:09:45.587 BUE: htsp_digit_ready(0/1/0:0(1)): Rx digit='#'
Jun  1 15:09:45.587 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_COMPLETE R2 Got Event R2_TONE_OFF
Jun  1 15:09:45.587 BUE: r2_reg_generate_digits(0/1/0:0(1)): Tx digit '#'
Jun  1 15:09:45.787 BUE: htsp_dialing_done(0/1/0:0(1))
Jun  1 15:09:46.587 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_WAIT_GUARD R2 Got Event R2_TONE_TIMER
Jun  1 15:09:46.587 BUE: R2_IN_CONNECT: call end dial
Jun  1 15:09:46.587 BUE: r2_reg_end_dial(0/1/0:0(1))htsp_call_service_msghtsp_call_service_msg not EFXS (11)
Jun  1 15:09:54.827 BUE: htsp_call_bridged invokedhtsp_call_service_msghtsp_call_service_msg not EFXS (11)
Jun  1 15:09:54.827 BUE: htsp_process_event: [0/1/0:0(1), R2_Q421_IC_WAIT_ANSWER, E_HTSP_CONNECT]
Jun  1 15:09:54.827 BUE: r2_q421_ic_answer(0/1/0:0(1)) E_HTSP_CONNECT
Jun  1 15:09:54.827 BUE: r2_q421_ic_answer(0/1/0:0(1)) Tx ANSWER seizure: delay 0 ms,elapsed 13344 msvnm_dsp_set_sig_state:[R2 Q.421 0/1/0:0(1)] set signal state = 0x4
Jun  1 15:09:54.831 BUE: r2_reg_channel_connected(0/1/0:0(1))
Jun  1 15:09:54.831 BUE: htsp_process_event: [0/1/0:0(1), R2_Q421_IC_ANSWER, E_HTSP_VOICE_CUT_THROUGH]
Jun  1 15:09:54.831 BUE: r2_reg_process_event: [0/1/0:0(1), R2_REG_WAIT_FOR_CONNECT, E_R2_REG_CONNECT(90)]
Jun  1 15:09:54.831 BUE: r2_reg_connect(0/1/0:0(1))
Jun  1 15:10:04.183 BUE: htsp_timer_stop3
Jun  1 15:10:04.203 BUE: htsp_process_event: [0/1/0:0(1), R2_Q421_IC_ANSWER, E_HTSP_RELEASE_REQ]
Jun  1 15:10:04.203 BUE: r2_q421_ic_release(0/1/0:0(1)) E_HTSP_RELEASE_REQ
Jun  1 15:10:04.203 BUE: r2_q421_ic_release(0/1/0:0(1)) Tx CLEAR BWDvnm_dsp_set_sig_state:[R2 Q.421 0/1/0:0(1)] set signal state = 0x4vnm_dsp_set_sig_state:[R2 Q.421 0/1/0:0(1)] set signal state = 0xC
Jun  1 15:10:04.203 BUE: r2_reg_channel_disconnected(0/1/0:0(1))
Jun  1 15:10:04.203 BUE: htsp_timer - 200 msec
Jun  1 15:10:04.203 BUE: r2_reg_process_event: [0/1/0:0(1), R2_REG_CONNECTED, E_R2_REG_DISCONNECT(91)]
Jun  1 15:10:04.203 BUE: r2_reg_disconnect_idle(0/1/0:0(1))
Jun  1 15:10:04.203 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_IDLE R2 Got Event R2_STOP
Jun  1 15:10:04.203 BUE: r2_reg_timer_stop(0/1/0:0(1))
Jun  1 15:10:04.339 BUE: htsp_process_event: [0/1/0:0(1), R2_Q421_IC_CLR_BWD, E_DSP_SIG_1000]
Jun  1 15:10:04.339 BUE: r2_q421_ic_clr_bwd_idle(0/1/0:0(1)) Rx IDLE
Jun  1 15:10:04.339 BUE: htsp_timer_stop
Jun  1 15:10:04.339 BUE: htsp_timer - 2000 msec
Jun  1 15:10:06.339 BUE: htsp_process_event: [0/1/0:0(1), R2_Q421_IC_CLR_FWD, E_HTSP_EVENT_TIMER]
Jun  1 15:10:06.339 BUE: htsp_timer_stop
Jun  1 15:10:06.339 BUE: r2_q421_clr_fwd_idle(0/1/0:0(1)) Tx IDLEvnm_dsp_set_sig_state:[R2 Q.421 0/1/0:0(1)] set signal state = 0x8
Jun  1 15:10:06.339 BUE: r2_reg_channel_disconnected(0/1/0:0(1))
Jun  1 15:10:06.339 BUE: r2_reg_process_event: [0/1/0:0(1), R2_REG_IDLE, E_R2_REG_DISCONNECT(91)]
Jun  1 15:10:06.339 BUE: r2_reg_disconnect_idle(0/1/0:0(1))
Jun  1 15:10:06.339 BUE: R2 Incoming Voice(0/0): DSX (E1 0/1/0:0): STATE: R2_IN_IDLE R2 Got Event R2_STOP
Jun  1 15:10:06.339 BUE: r2_reg_timer_stop(0/1/0:0(1))
pcolon-router#
pcolon-router#undl
Jun  1 15:10:12.579 BUE: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1188616282 1500 bytes is out-of-order; expected seq:1188590002. Reason: TCP reassembly queue overflow - session 10.170.0.250:52869 to 200.42.93.137:80
Jun  1 15:10:15.447 BUE: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:3173290892 1500 bytes is out-of-order; expected seq:3173263380. Reason: TCP reassembly queue overflow - session 10.170.0.250:53829 to 69.171.247.69:80und all
% Invalid input detected at '^' marker.
router#
Jun  1 15:10:17.271 BUE: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1582770122 1500 bytes is out-of-order; expected seq:1582736542. Reason: TCP reassembly queue overflow - session 10.170.0.250:62582 to 200.42.93.137:80und all
All possible debugging has been turned off
router#term no mon
You can look at 'Rx digit' to see if telco is sending calling number.
To eliminate 'dropping tcp segment' message, configure 'no ip virtual-reassembly' on all interfaces.
Community Member
Hello Paolo ,
when I type
I can see the Caller ID , I guess that is because the telco is sending OK the caller ID .
What can be the problem in this case ?
Thanks and best regards .
Hugo
975
