ali
Community Member
Can receive calls but not dial out both internal& External Numbers
I have a fault which one particular phone can receive calls but not dial out both internal& External Numbers
I have checked and the calling search space and partions config are all correct
Can anyone help with some pointers where I could look?
Cheers
Bronze
Re: Can receive calls but not dial out both internal& External N
CM or CME?
ali
Community Member
CM Thanks
All the other phones work fine just this one that just suddenly developed this fault.
I have also deleted and re-added the phone with the same issues
Community Member
Are you using extension mobility or are the lines assigned directly to the device. Check for unassigned extension number using the route plan report. What version of CM ?
ali
Community Member
No Extension Mobility the lines are assigned to the device.
Its Cisco Unified CallManager 4.2
285
