Community Member
Can SSLVPN Phones work without an ASA?
I have been trying to set up SSL VPN phones on a 3845 with CME8.6, but I've not been having much luck.  Is an ASA necessary for this to work?
Not only ASA is supported.
Not only ASA is supported. You can use IOS device as well:
https://supportforums.cisco.com/document/46346/cisco-ip-phone-anyconnect-vpn-ios
Community Member
The instructions you included
The instructions you included have instructions for IOS with a CUCM phone system.  I have CUCME.  Currently, there is no place for me to assign a vpn-group to an ephone in CUCME's web interface or via the command interface.
Are you saying that with just CUCME8.6 on a C3845 that I can configure SSLVPN for SCCP phones?
Community Member
I'm following this document
I'm following this document:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmevpn.html
Under my ephone config, I cannot enter a vpn-group or vpn-profile command.  These options also do not appear in the CME gui.
Yes, an ASA is necessary to
Yes, an ASA is necessary to terminate the VPN connections at your office.
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Are you saying that without
Are you saying that without an ASA, there is no way to configure SSLVPN SCCP phones with CUCME8.6 on a C3845?
73
