Can´t access to CUE by embedded service engine 0/0
Hi good morning, I am trying to access to CUE in a 2911 ISR with pre loaded software and ISM module and I followed the next sentence from techincal documentation in order to do it:
You must perform the configuration steps in this section, even if the CIMC-E software was factory-installed by Cisco.
Tecnical reference: http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/cimce/1.0/configuration/guide/CIMCe.html#wp1114378
  • •1.       Configure the embedded service engine 0/0 interface with an IP
SUMMARY STEPS
From the Host-Router CLI
1. enable
2. configure terminal
3. interface Embedded-Service-Engine 0/0
4. service-module enable
5. ip address module-side-ip-address subnet-mask or ip unnumbered type number
6. service-module ip address module-side-ip-address subnet-mask
7. service-module ip default-gateway gateway-ip-address
8. no shutdown
9. exit
10. ip route prefix mask ip-address
11. end
12. copy running-config startup-config
13. show running-config
14. reload
    • •2.      Next I check the module status and the output is UBOOT UP, the technical reference says that it is not correct (correct is KERNEL UP)
CME#service-module embedded-Service-Engine 0/0 status
Service Module is Cisco Embedded-Service-Engine0/0
Service Module supports session via TTY line 2
Service Module heartbeat-reset is enabled
Embedded Service Engine boot state is UBOOT UP
Module resource information:
  CPU Frequency: 500 MHz
  Memory Size: 256 MB
  Disk Size: 0 MB
No install/uninstall in progress
  • •3.      I can connect to the session (before, I could not) but, instead to send me to CUE, I see the boot-loader prompt, here I typed the show config command and this is the output:
CME#service-module embedded-Service-Engine 0/0 sess
Trying 192.168.1.1, 2002 ... Open
boot-loader > show config
IP Address:             <NULL>
Subnet Mask:            <NULL>
TFTP Server:            <NULL>
Gateway:                <NULL>
Default Helper-file:    <NULL>
Ethernet Interface:     <NULL>
Default Boot:           <NULL>
Default Bootloader:     <NULL>
Bootloader Version:     1.0
boot-loader >
From the output, the technical documentation says: If the Embedded Service Engine is stuck at the uboot prompt, it is possible that the uboot configuration is lost or corrupt. If the Default Boot field shown above is NULL, the uboot configuration read may have failed or the uboot configuration is corrupt. Enter the following command from the Cisco IOS software prompt:
Router# service-module embedded-service-engine 0/0 reset
I did that but after the reboot, the status is the same.
I am not sure if I am doing the correct process but if it is it, I dont know how to fix it, can anybody helpme?
Thanks a lot
Everyone's tags (1)
Hall of Fame Super Gold
Fill the boot loader values and tftp boot the installer.
Note the ip route step, has to to be a /32 route.
It is documented and there are varius thread on the subject
Hi Paolo, for the first point this is my configruration:
interface Embedded-Service-Engine0/0
ip unnumbered GigabitEthernet0/0
service-module ip address 192.168.1.2 255.255.255.0
service-module ip default-gateway 192.168.1.1
interface GigabitEthernet0/0
duplex auto
speed auto
ip route 192.168.1.1 255.255.255.255 Embedded-Service-Engine0/0
The second and third points are the outputs after I configured it and my problem is the service-module embedded-Service-Engine 0/0 status is in UBOOT UP
2463
