01-22-2014 06:27 AM - edited 03-16-2019 09:22 PM
Hi all
I have the following problem when using cisco call manager 9.
We can not add more than 6 users in a meet me.
basically we need to know where could it be the problem.
regards.
Solved! Go to Solution.
01-22-2014 06:47 AM
refer to this link and check also max session if you are using HW resources for meet-me
Br,
Nadeem
Please rate all useful post.
01-22-2014 06:29 AM
Check under the CUCM Service Parameters or if you're using hardware resources, check the DSPFARM Profile.
Yosh
01-22-2014 06:42 AM
You need to check both, the meet-me service parameter as that defines the overall limit, if you hit the HW CFB limit first, then that one has precedence.
This has been asked plenty of times before, please search CSC for answers before posting.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
01-22-2014 06:47 AM
Br,
Nadeem
