Can´t add more than 6 users in a meet me in CUCM 9.
Hi all
I have the following problem when using cisco call manager 9.
We can not add more than 6 users in a meet me.
basically we need to know where could it be the problem.
regards.
refer to this link and check also max session if you are using HW resources for meet-me
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080b2cd07.shtml
Br,
Nadeem
Please rate all useful post.
Br, Nadeem Please rate all useful post.
yahsiel2004
Level 7
Level 7
Check under the CUCM Service Parameters or if you're using hardware resources, check the DSPFARM Profile.
Yosh
HTH Regards, Yosh
You need to check both, the meet-me service parameter as that defines the overall limit, if you hit the HW CFB limit first, then that one has precedence.
This has been asked plenty of times before, please search CSC for answers before posting.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Br,
Nadeem
