Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Hall of Fame Super Gold
Can't add peer
This is a new problem that I'm posting in case someone else runs into it.
3845 w/ CME 4.1, IOS 12.4(11)XJ4. After almost six weeks of uptime on a busy installation, the error above is returned when trying to add ephone-dn.
Reloading router fixed the issue.
I would hope it can be reproduced for a bug to be filed, but realize that it may be difficult to do so... sigh.
Hall of Fame Super Silver
Re: Can't add peer
I have been deploying 12.4.15T for CME 4.1 and have not seen any issues. Perhaps upgrading IOS is a solution :-)
Chris
Re: Can't add peer
I have already posted this conversation in this forum, but i have not any solution.
I think the error is in the IOS version.
changing the IOS is the solution.
Re: Can't add peer
Sounds like a memory leak may be eating memory gradually. Each dial peer or ephone-dn takes up around 10K of memory. So if you have a leak, you run out of available memory to create the peers.
Something else to check - make sure you have not changed iomem settings - if there is too much memory dedicated for IO you can run out main system memory -
CME-Switch(config)#memory-size iomem ?
<5-50> percentage of DRAM to use for I/O memory: 5, 10, 15, 20, 25, 30, 40, 50
You may need to default this setting and reload the router.
Another gotcha is setting up 'logging buffered ' - this may prevent adding peers as it reserves system memory. Make the setting as low as possible or remove the command.
Re: Can't add peer
Yes, memory leak or data corruption.
However, I did a "show proc" and there was still plenty of free memory.
iomem is default a log buffer usage still small.
The problem here is that first is difficult to reproduce, and second, once it happens, all the sanity checks you can do are not pointing to the exact software cause.
Re: Can't add peer
Here it is again:
BA-CCME(config)#dial-peer voice 77 pots
ERROR: could not add peer
BA-CCME#sh proc mem sort hold
Processor Pool Total: 117465744 Used: 96805448 Free: 20660296
I/O Pool Total: 38796800 Used: 21563200 Free: 17233600
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 116183300 50218252 60500072 0 0 *Init*
0 0 893026544 851556164 32713272 6126032 0 *Dead*
261 0 335164464 303753536 4892608 0 0 VTSP
1 0 8015900 3493272 4533096 0 0 Chunk Manager
257 0 174658904 73822276 1653948 0 0 CC-API_VCM
272 0 36246228 50415460 1578064 0 0 CCSIP_SPI_CONTRO
311 0 14252136 24372472 1083460 0 0 AFW_application_
279 0 1016664 252 1041608 0 0 CCAAL2_CT
101 0 2091125848 842888792 653604 3489477588 30456 Skinny Msg Serve
67 0 669400 1328 650072 0 0 USB Startup
284 0 526600548 617412532 577996 0 0 ISDN
277 0 456208 0 481404 0 0 RTPSPI
270 0 367856 12564 383216 0 0 CCH323_CT
189 0 29465224 2529408 380420 11880 0 CCVPM_HTSP
302 0 10387644 3566172 355544 0 0 CCSIP-REGISTER
173 0 521232 556 318928 0 0 FLEX DSPRM MAIN
263 0 296984 252 303928 0 0 swmtp_msp
25 0 263332 0 272792 113400 0 EEM ED Syslog
203 0 247992 0 255188 0 0 QOS_MODULE_MAIN
278 0 203224 252 228168 0 0 CCFRF11_CT
6 0 6243524 7891524 220852 3038280 3911992 Pool Manager
275 0 185144 3436 209632 0 0 CCSIP_TCP_SOCKET
276 0 182864 252 207808 0 0 CCSIP_TLS_SOCKET
215 0 113261800 113026424 196716 4536 0 Crypto IKMP
274 0 44353024 34571420 189704 15876 0 CCSIP_UDP_SOCKET
260 0 132720444 174633464 182972 11340 0 DSMP
304 0 23107276 22969884 159184 0 0 Skinny Socket Se
95 0 11026660 1275876476 151308 62940 3488333796 IP Input
243 0 114240 8004 120824 0 0 EEM Server
217 0 136404 58336 115332 0 0 IPSEC key engine
4 0 35384968 35313124 97856 0 0 EDDRI_MAIN
211 0 477668 409228 93636 0 0 Crypto ACL
38 0 194960 2256 81376 2268 0 Net Background
216 0 66852 0 80048 0 0 Crypto IKEv2
120 0 74056 0 74036 0 0 CEF process
167 0 66548 252 73492 0 0 HTTP Process
295 0 644884 645268 64324 0 0 AFW_application_
200 0 940 0 62136 0 0 http client proc
262 0 34024 0 59220 0 0 TSP
92 0 49384 0 56580 0 0 ACCT Periodic Pr
186 0 46040 484 54752 0 0 Crypto WUI
268 0 240640 0 49800 0 0 Session Applicat
116 0 40808 1004 38880 0 0 DHCPD Receive
62 0 27504 252 34448 0 0 VNM DSPRM MAIN
172 0 27084 252 34028 0 0 CCVPM_HDSPRM
17 0 46972 21868 32300 0 0 ARP Input
45 0 45528 800 30672 0 0 rf task
318 578 82120 71464 28308 0 0 Virtual Exec
404
