Community Member
Can't Block Incoming Number
I'm having trouble blocking an incoming number on a Cisco 2811 configured as an h.323 gateway. I followed this guide here - http://blog.ipexpert.com/2009/03/21/blocking-calls-based-on-ani/. Everything seems to work okay. I can even successfully test the translation rule (test voice translation-rule 1 123), but when I call the main number with the phone that's supposed to be block, it still goes through. What am I doing wrong?
1 ACCEPTED SOLUTION
Hello Justin, I don't see the
Hello Justin,
I don't see the translation-rule in the attached configuration.
if you would like to block the specific calling number, please configure the translation rule and apply it to the inbound dial-peer as instructed in this URL.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/64020-number-voice-translation-profiles.html#con13
you may also refer this post for further information
https://supportforums.cisco.com/discussion/12116111/blocking-calls-incoming-calls-gateway-router?tstart=0
if the call is still not rejected, please collect the "debug voice ccapi inout" for a test call and include the specific calling number & called number to verify which translation rule and dial-peer they macth.
//Suresh
Please rate all the helpful posts.
//Suresh Please rate all the useful posts.
Could you please post the
Could you please post the debug voice ccapi inout output with the related translation rules and dial-peer configurations? Please include the calling and called numbers too.
Community Member
05-12-2014 11:15:02 Local7
05-12-2014 11:15:02 Local7.Info ip_address 153457: May 12 16:13:19.975: %ISDN-6-CONNECT: Interface Serial0/3/0:0 is now connected to 555-555-5555 N/A
05-12-2014 11:14:58 Local7.Info ip_address 153456: May 12 16:13:14.875: %ISDN-6-CONNECT: Interface Serial0/3/0:0 is now connected to 555-555-5555 N/A
05-12-2014 11:14:58 Local7.Info ip_address 153455: May 12 16:13:14.875: %ISDN-6-CONNECT: Interface Serial0/3/0:0 is now connected to 555-555-5555 N/A
05-12-2014 11:14:58 Local7.Info ip_address 153454: May 12 16:13:14.871: %ISDN-6-CONNECT: Interface Serial0/3/0:0 is now connected to 555-555-5555 N/A
Could you please collect
Could you please collect "debug voice ccapi inout" for the test call?
Community Member
I did, but how do I retrieve
I did, but how do I retrieve the log?
Community Member
Attached is the log you
Attached is the log you requested.
Could you post the running
Could you post the running configuration? What is the calling and called numbers?
Community Member
I attached the config. Why do
I attached the config. Why do you need the calling and called numbers?
Hello Justin,
//Suresh
114
