can't call 5-digit numbers ??
I have call manager 8.5 installed and a route pattern that route all calls to the gateway. No restrictions. I can make local calls , international calls and calls to mobile phones but I can't call 5-digit numbers. I get external line with 0 and when I hit the first 2 numbers I get busy tone. i live in Greece and all local numbers and mobile numbers have 10 digits. Local numbers start with 21XXXXXXXX and mobile numbers start with 69XXXXXXXX. Information numbers which is 5-digit numbers start with 1XXXX
My route pattern is 0@
Thank you.
1 ACCEPTED SOLUTION
Green
Re: can't call 5-digit numbers ??
Hi Patrick,
When you are using the 0.@ route pattern this infers that you need a dial plan
You should use the correct dial plan for your country
But you do need to set up the correct route filters
As you seem to be able to use the 0.@ pattern with NANP for the majority of your calls it
may be better to leave it alone
Try adding the route pattern 0.1XXXX as I suggested and drop the "0" at the appropriate location - may be
you already use a 0T destination on your dia peer in the router.
Alex
Regards, Alex. Please rate useful posts.
Green
This sounds like you have a "route filter" missing for 1XXXX numbers.
I am not sure about the Greek dial plan and if these calls are regarded as "Service"
You could try just ading a route pattern in the correct partition and point at the route list
Pattern 0.1XXXX ----> PSTN Route List or Gateway. Check the ROUTE URGENT field.
The other solution would be to create a Route Filter that matches the type of call probably "Service" or "Local 5 Digit"
clauses chosen as EXISTS
Alex
Ok.
I'll give it a try with the route pattern.
Should I have Greece Dial Plan installed for the route filter??? Because I have only North American Dial Plan .
Green
Hi Patrick,
Alex
Yes I use a 0T on the dial peer.
Does this affect it? Should I remove it?
What should I do?
Green
Patrick,
No --- do not remove it
Just send the 0.1XXXX pattern to the gateway direct or via your PSTN route list
Alex
I added the route pattern and I still can't call 5-digit numbers.
I hear a message from the provider that says that I can't make that call.
I called the provider customer service and they told me that's somethong wrong from my side.
How can I check what digits are being sent to the provider ?
from the router?
Hall of Fame Super Silver
Perform a debug on the voice gateway.  What type of circuit do you have for your service?
Alos, what protocol are you using to control it, if SIP/H323 make sure you have matching dial peers pointing to the circuit(s) on the GW.
Chris
I have a E1 PRI line.
I am using mgcp gateway.
How can I debug the voice gateway?
"Debug Isdn q931" works with MGCP as well, here are the steps:
ssh/telnet to the GW
  1. enter "debug isdn q931"
  2. enter "term mon"
  3. make the call
Chris
I have talked with the telephony provider and they told me that when I am calling a 5-digit number (let's say 13800) they get 113800 which means my callmanager or router is adding a "1". That's strange because I don't have any rule that does that nor something similar. Any ideas??
Review your Route Pattern, Route Lists, Gateway to ensure you are not prefixing the digit anywhere there.
Chris
833
