can't call from cucm7 to siemens hipath 3500
I have a problem, i can't call prom IP telehones managed by call manager 7.1, to siemens hipath :/
Here is a part of my configuration. and log info. Please advice?
interface BRI0/0/0
no ip address
isdn switch-type basic-qsig
isdn point-to-point-setup
isdn incoming-voice voice
isdn static-tei 0
trunk-group Local-PBX
dial-peer voice 100 pots
trunkgroup Local-PBX
translation-profile outgoing remove-prefix-4
destination-pattern .T
progress_ind progress enable 8
forward-digits all
dial-peer voice 200 voip
destination-pattern 9..
session target ipv4:192.168.192.61
dtmf-relay h245-alphanumeric
codec g711alaw
dial-peer voice 300 pots
incoming called-number .T
forward-digits all
Aug 19 07:39:33.290: ISDN BR0/0/0 Q931: Sending SETUP  callref = 0x00F0 callID = 0x8075 switch = basic-qsig interface = User
Aug 19 07:39:33.294: ISDN BR0/0/0 Q931: TX -> SETUP pd = 8  callref = 0x00F0
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Calling Party Number i = 0x0181, '997'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x80, '980'
                Plan:Unknown, Type:Unknown
Aug 19 07:39:33.366: ISDN BR0/0/0 Q931: RX <- SETUP_ACK pd = 8  callref = 0x80F0
Aug 19 07:39:33.378: ISDN BR0/0/0 Q931: RX <- CALL_PROC pd = 8  callref = 0x80F0
Aug 19 07:39:33.434: ISDN BR0/0/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x80F0
        Cause i = 0x859C - Invalid number format (incomplete number)
Aug 19 07:39:33.438: ISDN BR0/0/0 Q931: TX -> RELEASE pd = 8  callref = 0x00F0
        Cause i = 0x809C - Invalid number format (incomplete number)
Aug 19 07:39:33.470: ISDN BR0/0/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x80F0
1 REPLY
Super Bronze
Re: can't call from cucm7 to siemens hipath 3500
Looks like your number format is not correct - the hipath may be expecting a routing prefix or node number or something on the start of the numbers. You'll need to confirm what you need to send with the Siemens engineer.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
365
