07-08-2009 01:03 AM - edited 03-15-2019 06:51 PM
I have a problem to configure a trunk SIP on my CCM 4.2 SR3.
There's no problem to configure SIP trunk on Asterisk, but to configure this on CCM, you must before configure a MTP (Media Termination Point) on CCM.
However, I can't do this because I can't add a new MTP on CCM because I can't the IP adress of my asterisk on cisco. How can I do ?
In Host server, it tell me "not selected"
If you have an idea.
Jack
07-08-2009 07:09 AM
???? if you're running IPVMS on your server an MTP is already there, SW MTP can only be created within CCM servers running IPVMS and ONLY if you previously deleted it.
Have you looked at the MTP page of your server?????
java
if this helps, please rate
07-10-2009 04:32 AM
First, I have to explain you my architecture.
We have a cluster of 3 call manager, CCM1 (publisher), CCM2 & CCM3 (subscriber).
I have a new free PBX installed.
I would like to create a link between my free pbx and my call manager.
For that I created a sip trunk on my free pbx. Now I woult like create another sip trunk on my CCM.
How can I do ?
07-10-2009 07:46 AM
Hello Reseu,
what Java is saying is that the MTP server is likely already running in your cluster and it cannot be the SIP trunk destination.
you can check looking at media resources> MTP do a find and you should see the ip addresses of your servers
take not of their names (of MTP servers) and then in creating the SIP trunk you should specify one of them as the MTP
Hope to help
Giuseppe
