Community Member
Can't dial 800 numbers
I have a question, my users can't dial 800 numbers, when they try to call this is what I get. we have CCM 3.3 and the gateway is running h.323. we have the route patterns and the dial-peers configured
Calling Party Number i = 0x2181, '9163833333'
Plan:
dzl-2811#ISDN, Type:National
Called Party Number i = 0xA1, '18007887000'
Plan:ISDN, Type:National
*Dec 23 18:55:12.424: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x80D4
Channel ID i = 0xA98395
Exclusive, Channel 21
*Dec 23 18:55:13.176: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x80D4
Cause i = 0x82B9 - Bearer capability not presently authorized
*Dec 23 18:55:13.180: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x00D4
*Dec 23 18:55:13.188: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x80D4
dzl-2811#
30064771072d4294967296h: %ISDN-6-DISCONNECT: Interface Serial0/0/0:21 disconnected from 9168693597 , call lasted 37 seconds
"Cause i = 0x82B9 - Bearer capability not presently authorized"
this is the dial-peer on the gateway
dial-peer voice 800 pots
destination-pattern 918[06-7][06-7][2-9]......
port 0/0/0:23
forward-digits 11
thanks a lot
Re: Can't dial 800 numbers
You'll actually need to include the entire SETUP message to see the bearer cap. Looks like you cut it off for this setup. If you can paste a good setup message and the 1800 setup, you can compare them.
Community Member
I'm attaching the output of the entire debug and the output of the sh run
There's nothing in here that proves one way or the other.
ISDN provider issues are the biggest guessing game. You never really know *why* they're disconnecting, and you just guess or change things until it works.
Get a good call, get a bad call, compare them. Start changing things until it works, then back out things until it breaks again.
I don't see any good calls in the logs to compare. Contact your provider and see what's going on.
hth,
nick
Community Member
Do you have separate local and long distance trunks? 800 numbers are a local call, not LD.
480
