Community Member
Can't dial to DDI T1 trunk to Telco
Hi all,
We have set up a Voip config between Beijing and Hong Kong. However, I can't make call 00852xxxxxxxx to Hong Kong via the DDI T1 trunk. Please find the following reject code and partial config.
Reject code
11E9 : 33 11509260ms.32 +-1 +15100 pid:10 Originate 0085221279938
dur 00:00:00 tx:0/0 rx:0/0 6F  (protocol error (111))
Telephony 0/0/0:23 (33) [0/0/0.1] tx:0/0/0ms None noise:0dBm acom:0dBm
Config
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-4ess
isdn timer T310 60000
isdn not-end-to-end 64
isdn incoming-voice voice
isdn send-alerting
isdn disconnect-cause 3
no cdp enable
voice-port 0/0/0:23
mgcp behavior g729-variants static-pt
dial-peer voice 10 pots
trunkgroup VoIP
description ##  To HK local  ##
destination-pattern 00852T
forward-digits all
dial-peer voice 20 voip
description ##  To BJ  ##
destination-pattern .T
session target ipv4:192.168.1.2
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
dial-peer voice 1 pots
incoming called-number .T
direct-inward-dial
Leung Che Man
1 REPLY
Re: Can't dial to DDI T1 trunk to Telco
Don't see your trunk group defined under interface, maybe try first port with dial-peer and then with trunk group.
Usage Guidelines
Use this command to define the trunk group. Then if you decide to configure an interface for the Network Side ISDN PRI feature, use a trunk-group interface configuration command to assign the interface to a defined trunk group.
source: http://www.cisco.com/en/US/docs/ios/12_2/dial/command/reference/drfshux.html#wp1052726
rate if this help
153
