08-31-2014 12:46 AM - edited 03-16-2019 11:58 PM
Hello ,
When one of the Cisco phone call another inside the PBX and try add another phone via the sip
trunk it doesn't work .
I hear the third phone join the conference but it immediately hangs out.
Conference calls inside the CUCM works fine.
CUCM version 9.1.2.10000-28
Any idea?
08-31-2014 01:41 AM
Did you assign MRG with conference resource (in case of different codec it would be hardware conference) to sip trunk ?
Suresh
08-31-2014 02:28 AM
There is MRG with conference resource but it is software .
08-31-2014 02:47 AM
Then you need to assign hardware conference if you are using codec other than g711/722 at sip trunk, so assign it once and then test.
Suresh
09-01-2014 01:46 AM
I spend the last day trying to understand how to configure hardware conference bridge without ruin other configuration in the router .As far as I understand the configuration starts with :
sccp local GigabitEthernet0/2.2
sccp ccm 10.130.131.9 identifier 1 priority 1 version 7.0
sccp ccm 10.130.5.1 identifier 2 priority 2 version 7.0
But I don't understand on which GigabitEthernet I should configure this .
09-02-2014 01:12 AM
Hello!
You should specify interface, from which your CUCM is accessible.
Kirill
09-02-2014 01:29 AM
Can I add this to GigabitEthernet0/1 that already configured ? and accessible to the CUCM?
interface GigabitEthernet0/1
description ++++ Connected To Lan ++++
ip address 192.168.188.253 255.255.255.0
ip helper-address 192.168.180.11
ip flow ingress
ip flow egress
standby 0 track 1 decrement 10
standby 1 ip 192.168.188.254
standby 1 priority 110
standby 1 preempt
ip tcp adjust-mss 1420
load-interval 30
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.188.253
09-02-2014 01:45 AM
Just add
sccp local GigabitEthernet0/1 (under global configuration mode, NOT interface config)
sccp ccm <CUCM_IP_1> identifier 1 priority 1 version 7.0
sccp ccm <CUCM_IP_2> identifier 2 priority 2 version 7.0
sccp
sccp ccm-group 1
associate ccm 1 priority 1
associate profile 1 register <name_specified_in_CUCM>
dspfarm profile 1 conference universal
codec ...
maximum-session ...
associate application SCCP
no shut
09-02-2014 05:35 AM
Hello ,
Thank for your reply !
I added this configuration in the CUCM the conference bridge is still
REJECTED
voice-card 0
dspfarm
dsp services dspfarm
sccp ccm 192.168.180.2 identifier 2 priority 2 version 7.0
sccp ccm 192.168.180.3 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
associate ccm 2 priority 2
associate profile 1 register TESTBEN
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 6
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
09-02-2014 05:58 AM
This means something is conflicting between what CUCM expects for registration and what the CFB is sending it for regn.
Check the CUCM Group under the device pool for the CFB and make sure the order of CUCM servers is the same as this:
Also make sure that the name configured is the same. It is case sensitive.
09-02-2014 06:47 AM
So I was able to figure out the problem (REJECTED)
under sccp ccm group 1 I associated profile 1 instead of profile 2 .
I tested the original problem with the hardware conference bridge but it doesn't work .
While the customer speaks with someone via sip trunk and try to conference someone else
the call to the other PBX hang out and he stays in call with second call.
09-02-2014 06:47 AM
I suggest resetting the transcoder once. Usually when you configure it for the first time, it'll be in rejected and once you reset, it'll go to registered.
You can also do a no sccp, followed by sccp on the router.
Also run the show sccp command and see the state of the transcoder after the reset.
09-02-2014 11:48 PM
My goal was to configure conference bridge but I got registration UNKNOWN
I configured the transcode just for test and then got rejected.
The reset and the "no sccp , sccp " didn't work
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/1
IPv4 Address: 192.168.188.253
Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.180.2, Port Number: 2000
Priority: 2, Version: 7.0, Identifier: 2
Call Manager: 192.168.180.3, Port Number: 2000
Priority: 1, Version: 7.0, Identifier: 1
Transcoding Oper State: ACTIVE_IN_PROGRESS - Cause Code: CCM_REGISTER_FAILED
Active Call Manager: 192.168.180.3, Port Number: 2000
TCP Link Status: NOT_CONNECTED, Profile Identifier: 1
Reported Max Streams: 4, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
09-03-2014 09:41 AM
When you're adding the transcoder on CUCM, are you using the Cisco IOS Enhanced Media Termination Point type? Or are you configuring the transcoder as some other type? And for the CFB, are you configuring it as IOS Enhanced CFB?
09-04-2014 12:22 AM
the call to the other PBX hang out and he stays in call with the second call.
If I change the MRGL in my phone it works. When I call via sip and I can see
the conference in the router but when I assign this MRGL to sip trunk it doesn't work (doesn't use the resources of the router )
