Can't fax with VG224
I'd like to set up VG224 to support analog phones, modems, and fax machines with extensions on DID blocks. I've followed Cisco's SCCP Controlled Analog (FXS) Ports doc, and have successfully configured a voice port for an analog phone. However, the same config doesn't work when attaching fax machine. Fax machines generally transmit/receive faxes to/from external parties, not over IP WAN.
Recent posts recommend MGCP over SCCP but suggested configs may not work in my environment. I have a PRI terminating on a Catalyst WS-X6608-T1 module. CallManager 4.1(3)SR4d in single cluster, VG224 running 12.4(2)T5, configured in CCM as SCCP gateway with all 24 endpoints as analog phones.
Anonymous
N/A
Re: Can't fax with VG224
version 12.4
no service pad
service password-encryption
service sequence-numbers
hostname vg224
boot-start-marker
boot-end-marker
logging buffered 512000 debugging
no logging console
no aaa new-model
resource policy
clock timezone PDT -7
clock summer-time PDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
clock save interval 8
ip subnet-zero
no ip dhcp use vrf connected
stcapp ccm-group 1
stcapp
voice-card 0
voice service voip
modem passthrough nse codec g711ulaw
interface FastEthernet0/0
description VG224 on Cat6509
ip address 10.0.123.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.123.1
ip http server
control-plane
voice-port 2/10
description analog_ph_test
caller-id enable
voice-port 2/11
description facsimile_test
caller-id enable
sccp local FastEthernet0/0
sccp ccm 10.0.123.4 identifier 7835 version 4.1
sccp
sccp ccm group 1
associate ccm 380 priority 1
dial-peer voice 9910 pots
destination-pattern 210
port 2/10
dial-peer voice 9911 pots
destination-pattern 211
port 2/11
Anonymous
N/A
Anonymous
N/A
Anonymous
N/A
Silver
Here is a note from the Restrictions section of SCCP notes:
?Modem and fax-relay are not supported on FXS ports with SCCP enabled; only modem and fax pass-through are supported. Configure FXS ports with either fax or modems attached in H.323 or SIP mode.
http://www.cisco.com/en/US/products/ps6441/products_feature_guide09186a0080483a76.html
I think on the 6608, you enable fax passthrough by unchecking the fax relay box. This would be your best hope, and hope that the passthrough on the VG224 and the 6608 are the same flavor..
Mary Beth
Silver
Found this in the SRND:
At a high level, Cisco IOS Release 12.3(1) - Load 47 on the Cisco 6608 and Load 41 on the Cisco 6624 - and Release 1.2.1 on the VG248 do support interoperability of Cisco fax relay, modem pass-through, and voice features. Prior to Cisco IOS Release 12.2(11)T1, only voice and Cisco fax relay were supported between Cisco IOS and non-IOS voice platforms because incompatibility of the pass-through Named Service Event (NSE) scheme prevented modem pass-through from interoperating
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_implementation_design_guide_chapter09186a00806e8c11.html#wp1045781
So, it might be that you want to check the load on the 6608, and make sure you have a newer load, for the best hope of success..
Mary Beth
Anonymous
N/A
454
