Can't find MD5 for CUCM upgrade 7.1(3)ES31
I'm looking for the MD5 value on 7.1(3)ES31 (UCSInstall_UCOS_7.1.3.30000-1).  Is it 1b2af45a842ac686492d2c0cd5aae85b  ?
We are running CUCM version 7.1.3ES26.32900-26 and going to upgrade to 7.1(3)ES31 (UCSInstall_UCOS_7.1.3.30000-1).  I was sent the links from TAC and given the MD5 sum for the two files.  Now that I've combined the two files the MD5 sum is 1b2af45a842ac686492d2c0cd5aae85b .  I'm looking for confirmation that is correct.  When it was published for us by TAC they only provided the two individual MD5's before they were combined.
Mike
1 ACCEPTED SOLUTION
Re: Can't find MD5 for CUCM upgrade 7.1(3)ES31
The final file should have MD5
1b:2a:f4:5a:84:2a:c6:86:49:2d:2c:0c:d5:aa:e8:5b.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
That's no ES. It's 7.1(3b)
UCSInstall_UCOS_7.1.3.30000-1.sgn.iso_part1of2
Release  Date: 15/Dec/2009
Cisco  Unified Communications Manager 7.1(3b) part 1 of 2 (non-bootable) -
From README
b. If you have a Windows system, copy and paste the following command into the command prompt
(cmd.exe):
Step 3 Use an md5sum utility to verify that the MD5 sum of the final file is correct.
6180c0b0c9ff1b0893a88988c154d94b UCSInstall_UCOS_7.1.3.30000-1.sgn.iso
java
java
Hall of Fame Super Red
Hi Mike,
I agree with Java (+5 "J")
UCOS_7.1.3.30000-1 would be a "downgrade" from your current version which you said is
@ 7.1.3ES26.32900-26
Release Notes for Cisco Unified Communications
Manager Release 7.1(3b)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_3/cucm-rel_notes-713b.pdf
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Thanks for the quick responses.  My mistake!  I had originally asked for CUC7.1.3ES31.  TAC recommended CUC7.1.3ES33.  The upgrade links they sent me are:
UCSInstall_UCOS_7.1.3.33027-1.sgn.iso_part1of2
UCSInstall_UCOS_7.1.3.33027-1.sgn.iso_part2of2
The TAC engineer told me this is to apply ES33.  I'm looking to verify the MD5 of the combined file.
java
java
Thanks!!  That matches what I have.  Much appreciated!
368
