Can't get Phones to Work
I have a customer with 15 users  who are using third party "One IP Telephone System.   The VoIP phones  are connected a Cisco Switch and Cisco switch is connected to Cisco 871  Router.  They are using cable modem for SIP and Internet.
They are able to make outbound calls but with incoming calls, One   person is able to answer the phone but after that all other phones  still  ring but as soon as the call is answered the call is dropped)  They are  using are 3rd party company for there VOIP service.
Previously,  they were using Linksys router and there was no issue with the incoming  calls, but after replacing Linksys with Cisco Router they are having  issues with incoming calls.
I am not able to troubleshoot the issue, and will appreciate if someone can help
Below is the Cisco router config
class-map type inspect match-all sdm-nat-user-protocol--1-1
match access-group 101
match protocol user-protocol--1
class-map type inspect match-any ccp-skinny-inspect
match protocol skinny
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp extended
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any cpinspectclass0
match protocol http
class-map type inspect match-any ccp-h323-inspect
match protocol h323
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect sdm-nat-user-protocol--1-1
  inspect
class class-default
policy-map type inspect ccp-inspect
class type inspect cpinspectclass0
  inspect
   urlfilter SDM_URLFILTER_MAP
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-h323-inspect
  inspect
class class-default
class class-default
zone security in-zone
zone security out-zone
zone-pair security ccp-zp-out-self source out-zone destination self
service-policy type inspect ccp-permit
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description WAN interface to ISP using STATIC IP$ETH-WAN$$FW_OUTSIDE$
ip address 23.189.52.251 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
zone-member security out-zone
duplex auto
speed auto
interface Vlan1
description LAN switch ports on inside interface$FW_INSIDE$
ip address 192.168.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
zone-member security in-zone
ip route 0.0.0.0 0.0.0.0 23.189.52.251
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list NAT-ACL interface FastEthernet4 overload
ip nat inside source static tcp 192.168.10.10 3389 interface FastEthernet4 3389
ip nat inside source static tcp 192.168.10.5 3390 interface FastEthernet4 3390
ip access-list standard VTY-ACL
permit 192.168.10.0 0.0.0.255
ip access-list extended NAT-ACL
permit ip 192.168.10.0 0.0.0.255 any
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 23.189.52.248 0.0.0.7 any
access-list 101 remark CCP_ACL Category=0
access-list 101 permit ip any host 192.168.10.10
261
