Can't log on CCM Administration
I have CCM integrated with AD.
I use CCMAdministrator for log on CCM Administration.
Now, there is no connection between AD and CCM and I can't log with CCMAdministrator.
How can I log now on CCM Administration? Can I change password for CCMAdministrator somewhere local on server? How can I log on CCM Administration now?
thanks
Re: Can't log on CCM Administration
Sounds like you're using MLA? Take a look at the following link which describes disable MLA in SQL. You will then be able to use the local administrator username/password to access CCM administration.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800e1691.shtml#newtopic
Hope this helps. If so, please rate the post.
Brandon
Thanks a lot Brandon.
This was very helpfull!
Brandon,
Thank you so much for posting this. You completely saved my skin. I didn't know that the administrator login would no longer work after enabling MLA and was about to be facing a long day on the phone with TAC. Now I am back up and running and know what to do going forward. You Rock!!
110
