can't login to Personal Communicator - freezes
craigvoice
Trying to install on XP laptop. It installs ok but after launches it only allows me to enter a few keys in username/password box then freezes. Tried uninstall/reinstall, tried .exe/.msi files.
Does it matter that IP Communicator also on laptop?
gogasca
Level 10
Level 10
It should work fine, which version you are using for CUPC?
It was working fine at some point?
