Can't make offnet calls from IP Communicator running on Vista
We are running UCM 6.0 BE.
We indstalled IP Communicator on Microsoft Vista. I can able to receive calls from offnet,but i can't able to make offnet calls.
(within the LAN it is working fine)
Pls help me out..
Re: Can't make offnet calls from IP Communicator running on Vist
Have you looked at your CSS and verified that you can make outbound calls to the pstn?
please clarify what's the behavior
do you get busy tone?
dead air?
the message "your call cannot be completed as dialed..."?
this might be a codec issue, look into the region settings and also the "optimize for low BW" option in the CIPC preferences
javalenc
java
if this helps, please rate
www.cisco.com/go/pdi
141
