Can't transfer call using CUBE
I hope someone can help me, this is the problem. I have a CUCM 8.5 whit a CUBE as h323 gateway. CUBE uses SIP to connect to an asterisk system, like this:
CUCM ---h323--- CUBE ---SIP--- Asterisk
Calls work fine, but when i try to transfer a call in CUCM side, it dont work. I was trying modified mtp requiered, but using mtp, i press transfer and nothing happen, if I not use mtp, i press transfer and call get down.
CUBE config is attached, I would really appreciate any help.
Carlos
1 ACCEPTED SOLUTION
Re: Can't transfer call using CUBE
Hi Carlos.
So i suppose asterisk users are using g729 codec or cube definition has been forced to use this codec.
Configure IOS mtp service on cube to use g729 and assign it to a new media resource group on cucm. assign mrgl to h323 gateway.
Hope this helps.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlos.
Please post the output of a show sccp connections while in call with an asterisk extension.
Can you also post the asterisk sip.conf portion regarding the connection to the cube?
Leave chcked the "Mtp required" option on the CUCM
Carlo
Hi Carlo, thanks for your answer, this is waht i get
CUBE_CAM#sh sccp connections
sess_id    conn_id      stype mode     codec   sport rport ripaddr
5          6            xcode sendrecv g711u   18956 2000  172.29.129.1
5          5            xcode sendrecv g729    16602 2000  172.29.129.1
Total number of active session(s) 1, and connection(s) 2
MTP requiered is checked.
Asterisk is manage by other people, I ask for the sip.conf, and I will post it as soon I have it.
Hi Carlos.
Try to apply g711ulaw codec to all CUBE dialpeers a check if something changes.
Carlo
I apply g711ulaw for all dialpeers, but now, call rings and fall down when other side answer.
Carlos
Hi Carlos.
Hope this helps.
Carlo
Hi Carlo,
Actually CUBE use g711ulaw with Asterisk and g729 with CUCM.
CUCM ---h323(g729)--- CUBE ---SIP(g711u)--- Asterisk
I am using an transcoder configured in CUBE as MTP resource in CUCM, and is aplied in an MRGL which is assign to the h323 gateway (CUBE).
Is there any debug can I make which show me what is happening while I press transfer button?
Carlos
Collect CUCM sdi/sdl traces and filter based on transfer number.You can get to know the reason why the transfer fails.
Siva
pls rate if helps you.
Hi Everyone,
Finally I can solve this problem, As Carlo said I just configure an ios MTP g729 on CUBE, and then registered it on CUCM to use in MRGL assigned to h323 gateway. When I try it first time I use an ios transcoder as MTP, but it must to be an ios MTP.
Thanks a lot
760
