Community Member
Can't transfer calls while in SRST
I am having a problem configuring SRST. Any suggestions would be appreciated
While in SRST call transfers fail with a "no line available" message.
SRST commands below
call-manager-fallback
max-conferences 10 gain -6
transfer-system full-consult
ip source-address X.X.X.X port 2000
max-ephones 40
max-dn 80
transfer-pattern .T
1 ACCEPTED SOLUTION
Community Member
Re: Can't transfer calls while in SRST
Check if the ephone-dn have dual line?
If not, it will fail as you have full-consult for transfer.
1 REPLY
Community Member
448
