Can unity be integrated with exchange through internet for unified communication
Hi all,
Is it possible to configure unity for unified messaging where the access to  exchange server is through internet(public IP address)?
Bijin
1 ACCEPTED SOLUTION
Re: Can unity be integrated with exchange through internet for u
As there is no version I'll go with 8.X
Supported Exchange Configurations—Message Store
Revised July 2, 2010
Caution Configuring Cisco Unity to access mailboxes for  Cisco Unity subscribers in a hosted Exchange environment or choosing a  partner Exchange server in a hosted Exchange environment is not  supported.
Also
Network Requirements
Revised May 3, 2010
For new installations, a minimum  network bandwidth of 100 Mbps between the Cisco Unity server and the  following servers:
The partner Exchange server.
Any Exchange server on which  Cisco Unity subscriber mailboxes are homed.
The domain controller that Cisco Unity  monitors for directory updates.
The global catalog server that  Cisco Unity monitors for directory updates.
The global catalog server with which  the Cisco Unity MAPI client communicates.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/8x/requirements/8xcusysreq.html#wp494986
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Also
Revised May 3, 2010
java
java
Hi Java,
Thanks for your answer.
170
