Can we add Software conference Bridges on Call manager Publisher
Dear All,
I am having call manager 8 on Publisher and 2 subscribers.
I am having conferance Bridges on Subscriber ,But for some reason I need to move the subscriber ,
so I am planning to move the conferance bridges on Subscriber  to Publisher,
So is it feasible to have conferance bridges on publisher.
Please help me out
Deepak
The SW CFB is tied to the server as it depends on the IPVMS running PER server, there is no way to move the CFB from one server to another. The only thing you can do is decide on which server they're going to be registered, but the actual media mixing is done in each server.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Hi javalenc ,
You mean to say I need to share the conf bridges on Publisher and subscriber.
Deeps
The CFB is tied to the IPVMS, only one instance runs per server and the actual mixing of the streams is done per server. You cannot "move" the IPVMS from one server to another.
You're not going to actually move any CFB, you either enable/disable them in each server.
If it's not enabled in the PUB as Chris mentions you can do it, just make sure to properly adjust your MRG/MRGL
java
java
Hall of Fame Super Silver
Yes, the IP Voice Streaming can be started on the Publisher,and media resources can be used, not ideal, but doable.
Chris
191
