can we connect panasonic cordless phone to AUX port of cisco ip phone 7965
hi,
I want to connect panasonic kx-tgc210c phone to AUX port of cisco ip phone 7965.
is it possible??
i have connected and tested: panasonic phone showing check tel line message.
please help!
thx
Sapinder
The AUX port is for expansion
The AUX port is for expansion modules - like external keypads, etc. You'll want to get an ATA 186/187 or plug the cordless phone directly into an FXS card on your router.
  is there any way I can
  is there any way I can connect Panasonic phone using some sort of RH45 to RJ11C converter?
just want cordless phone instead of cisco ip landline phone.
You may be able to, but I've
You may be able to, but I've never seen it done and it wouldn't be supported. An ATA would be a quick and easy solution to implement what you're looking to do.
This discussion has been
This discussion has been reposted from Cisco User Groups to the IP Telephony community.
613
