Can we mix various servers within single cluster?
Let's say I want to use MCS 7815,MCS 7825 and MCS 7835 for doing one cluster. Can I do this. I wanna use CCM6.0.
Thot
pklos
Level 4
Level 4
Yes, you can use different server for single cluster.
regards,
pk
Hi Pk.
Thanks for helping me out.
Could you provide me with some reference documents?
Thot
Thot,
The closest I could find for you is this:
<http://www.cisco.com/iam/unified/ipt601/Prepare_and_Plan.htm>
and,
<http://www.cisco.com/iam/unified/ipt601/Use_Planning_Tools_and_Templates.htm>
hth,
Ajaz
pls rate this post if it helped
